Author: Subject: Unleaded Fuel Pump Nozzle Diameter
davidimurray
posted on 2/5/14 at 10:13 PM Reply With Quote
Anybody happen to know what diameter the end of a petrol pump is, the bit you stick down the filler nozzle?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
theprisioner
posted on 2/5/14 at 10:50 PM Reply With Quote
From Wiki....
"Motorists occasionally pump gasoline into a diesel car by accident. The converse is almost impossible because diesel pumps have a large nozzle with a diameter of 15⁄16 inch (23.8 mm) which does not fit the 13⁄16-inch (20.6 mm) filler, and the nozzles are protected by a lock mechanism or a liftable flap......................."
cbs says
"Vehicle fitted with engines manufactured after 1993 must have a restrictor fitted............................"
I did not have one fitted at the time and it passed the IVA test last year. I guess it depends on the IVA man.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
40inches
posted on 2/5/14 at 11:42 PM Reply With Quote
A restrictor is no longer required for IVA, but a cap lock or tether still is.
