kj
posted on 5/5/14 at 04:19 PM |
zx9 starting problem
Everything connected held the wires onto switch bloody hot is that normal. Anyway it turns over but nothing I can't hear the fuel pump so have I
missed something.
Think about it, think about it again and then do it.
wylliezx9r
posted on 5/5/14 at 04:40 PM |
missed something.
Clutch and stand interlocks ? Resistor (of which I can't remember the value) on the ignition to cdi feed. It won't run without it, it
would be part of the bike ignition barell but I'm guessing your not using that.
HTH
George Best
YQUSTA
posted on 5/5/14 at 04:43 PM |
The resistor is 100 ohm iirc.
"If in doubt flat out"
Colin McRae
kj
posted on 5/5/14 at 04:58 PM |
Resistor fitted 100 ohm all circuts bypassed
YQUSTA
posted on 5/5/14 at 06:04 PM |
Have you tried to apply power direct to the pump to see if it works?
Colin McRae
kj
posted on 5/5/14 at 06:21 PM |
Will give it a go at the weekend busy with work
YQUSTA
posted on 5/5/14 at 06:31 PM |
That's where I would start, if the pump then works I would test for voltage to the pump when you are turning the engine over.
I don't like the idea that the cables are getting hot when you are cranking the engine though, doesn't sound right to me.
do you still have the starter relay wired in?
Colin McRae
kj
posted on 6/5/14 at 08:28 PM |
Ok seen a few different options,white grey with resistor the permanent live on sierra switch and brown to cranking.
