Author: Subject: Who can make me a fuel tank for my tiger please?
jossey
posted on 12/5/14 at 06:55 AM Reply With Quote
Just need one with a hole for the sender unit and the output at the bottom for my bike engine...
Dj
[Edited on 12/5/14 by jossey]
David Johnson
femster87
posted on 12/5/14 at 07:24 AM Reply With Quote
Mkengineering mate
CosKev3
posted on 12/5/14 at 07:29 AM Reply With Quote
http://www.mkengineering.co.uk/?no_redirect=true#2231
Martin made a tank for Dug that's building the orange MK indy in the BEC section of forum, its spot on and very well priced
He will make it to your spec/drawings.
dhutch
posted on 12/5/14 at 07:45 AM Reply With Quote
Do tiger not supply a tank? or are you after a bit of a special?
PAUL FISHER
posted on 12/5/14 at 08:50 AM Reply With Quote
Another vote for Martin at MK Engineering, superb quality, at a good price.
jossey
posted on 12/5/14 at 09:05 AM Reply With Quote
Tiger do a tank but it has the fuel feed at the top which is causing a few issues for my bec.
I want one at the bottom to help fuel flow.
It's ok at the mo when the tank is full but while out at the weekend it starting running funny when the fuel level dropped low.
Plus the sender unit hole is a wierd size so I ain't using any fuel sender which ain't fun either lol.
Mile per gallon ain't easy to calculate without a speedo or fuel sender lol.
David Johnson
rdodger
posted on 12/5/14 at 09:08 AM Reply With Quote
Bryn at Allyfab did mine. Great Job.
JacksAvon
posted on 12/5/14 at 09:25 AM Reply With Quote
I just had one fitted by Tiger with a small sump in it at the bottom left corner and the fuel outlet from there.
Also fitted with a working fuel sender.
jossey
posted on 12/5/14 at 11:33 AM Reply With Quote
Thanks all.
David Johnson
jossey
posted on 12/5/14 at 11:37 AM Reply With Quote
Wasn't aware but thanks all compare quality and price with mk and tiger.
David Johnson
blakep82
posted on 12/5/14 at 04:16 PM Reply With Quote
http://www.alloyracingfabrications.com/fuel-tanks/westfield.html
Theres a locost one there too, but if you ask him, he can make any changes needed
________________________
stevebubs
posted on 12/5/14 at 04:25 PM Reply With Quote
another vote for Bryn @ Allyfab..
zetec-phill
posted on 12/5/14 at 06:38 PM Reply With Quote
tank
u2u
matty h
posted on 12/5/14 at 06:49 PM Reply With Quote
I use a chap at Normandy near Scunthorpe called Forge weldingfor all my ali and stainess welding made my brother a ai tank. Can send you details if intrested.
Matty
