dan8400
posted on 19/5/14 at 02:04 PM |
Golf and passat drive shaft question
Hi everyone
I am building a single seater with a passat / audi a4 engine. Just wondered if the bolt on driver shafts from a golf fit?
I need longer shafts than the passat ones. If this is the case I can use two drivers side shafts from the golf.
Alternately, what are my options for lengthening the shafts I have. And what price am I looking at to get it done?
Dan
Hey - That's Journey!!!
ian locostzx9rc2
posted on 19/5/14 at 02:54 PM |
The bolt pattern is the same for both sides..
dan8400
posted on 19/5/14 at 02:55 PM |
Same for a golf and passat? Are they interchangeable? The passat has a transaxle. The golf is transverse
Dan
ian locostzx9rc2
posted on 19/5/14 at 02:57 PM |
I'm pretty sure the drive flanges are the same.
dan8400
posted on 19/5/14 at 02:59 PM |
Ok that's good thanks Ian
minitici
posted on 19/5/14 at 04:02 PM |
You might even find that the shafts have the same splines on the inboard ends and can fit 90 or 100mm joints?
