jchaynes
posted on 23/5/14 at 07:48 AM |
ldv maxus help
If anyone can be bothered to read my essay anyone's thoughts would be appreciated.
I will give you the whole story just in case anything is related.
I bought a 2006 van With 80000 on the clock which ran well it always turned over a couple of times before starting but nothing alarming.
When it was really cold last winter i couldn't start it and I changed the glow pugs which then solved the problem.
A few months after this the van started to become more difficult to start but there didn't seem to be a pattern.
One day I couldn't get it started at all so called RAC and when the guy turned up he turned the key and it started. he said it was fuel draining
back, so he said to pump the fuel filter pump before starting, but I later found that this didn't make a difference.
Also a note is that after the van had been started it would then start again no probs.
The van then stopped starting at all.
I took it to a garage which it has been in ever since.
They couldn't get any diagnostics off the van (which I can vouch for as the RAC man plugged in his laptop and couldn't get any more than 2
readings) so they sent the ECU to be tested which said the ecu was nackered and couldn't be fixed.
They bought another one of eBay which when fitted didn't get the van running but did then give them all the information on the computer.
They then said they there was a fuel pressure problem and the injectors were shot so they were tested and found to be nackered.
They also tested the high pressure diesel pump that was fine. So they replaced the injectors which has now got the van running.
But they say it is still not starting well and once its running its smoking a bit and they said there is some oil coming from the rocker breather and
in the inlet manifold.
They have checked the timing and done a compression test all of which were between 200 and 250 psi.
There is also now a fault code that is apparently an accelerator pedal fault that when they take the van out puts it into a limp home mode but it
doesn't seem like that would effect the starting/smoking and oil things
I am now at a complete loss as to what to and would really like to know your thoughts.
And yes a can of petrol and a match has already been considered.
posted on 23/5/14 at 08:08 AM |
I can't help with the problem but thanks for sharing - I was thinking of getting one but that sounds awful
jchaynes
posted on 23/5/14 at 08:50 AM |
I was in the middle of converting it to a camper so I'm in so deep that I can't let it beat me!! But yes on reflection there may be better
vans out there!
bigrich
posted on 23/5/14 at 12:02 PM |
Main things that stop Maxus starting up are
Incorrectly rated battery. They should be fitted with a 900 A/h battery not the 680 that was initially used at start of production.
Secondly crank sensor airgap becomes an issue due to block corrosion lifting and distorting the sensor. Also if the sensor has been removed they can
be awkward to reinstall correctly and often get damage by use of the bolt to pull them home.
High pressure pumps generally good and if failing Do so under load.
Hth Bigrich
jchaynes
posted on 23/5/14 at 03:48 PM |
Thanks rich any ideas on the smokey running and this oil coming from the rocker breather? I don't know if those compression readings are any
good as can't find info on what they should be.
bigrich
posted on 23/5/14 at 04:24 PM |
Chech the air induction pipe from airbox to turbo. The plastic degrades and blocks the stub where the breather hose joins it, they also split and
swell up.. This was modified to a different hose on production. Changed literally hundreds of them for blue smoking and oil leaks
Rich
jchaynes
posted on 3/6/14 at 09:41 AM |
Hi rich. The garage has said they have checked those and still doesn't seem to help would you mind if the guy called you as its my last attempt
at getting this thing running before the costs become unviable. It would be a great help if you don't mind. Thanks john
