Author: Subject: material to use for curved aeroscreen
Mistron
posted on 26/5/14 at 07:00 PM Reply With Quote
Hi Folks,
Has anyone got any ideas for the best material to use for curved aeroscreen - I'd prefer not to use heat unless I have to.
Here's my mock up in card.
Any ideas / suggestions?
Al
40inches
posted on 26/5/14 at 07:08 PM Reply With Quote
2mm polycarbonate will bend to that form easily
Matt21
fibre glass?
Mistron
posted on 26/5/14 at 07:11 PM Reply With Quote
not GRP - I want clear
I wondered about 3mm 'LEXAN CLEAR EXELL D' but wasn't sure it'd take the shape. would 2mm be rigid enough?
Al
austin man
posted on 26/5/14 at 08:35 PM Reply With Quote
Why dont you want to heat it as long as you have something to form it around, gentle heating with a hot air gun will be fine
40inches
posted on 26/5/14 at 10:59 PM Reply With Quote
Al
2mm would be fine. However I have some 3mm Exell D if you let me know the radius you want to bend to I will see if it will.
[Edited on 27-5-14 by 40inches]
ali f27
posted on 27/5/14 at 09:24 AM Reply With Quote
Why not use bubble screen of motorbike i was going to use ducati one still have it somewhere
Mistron
posted on 27/5/14 at 08:55 PM Reply With Quote
Al
It's about 30omm Dia / 150mm radius
Mistron
posted on 24/8/14 at 07:05 PM Reply With Quote
Well, I'm pleased to confirm that 3mm lexan did the job very well, with the assistance of the gas cooker.
I read all the horror stories about Lexan bubbling internally when you got it hot enough to bend, so I tried it with an off-cut first, then with the screen profile. Both went without incident.
It's not quite tight enough a curve yet - i'm workign it slowly, bit at a time, but it has enough defelction now that it could be bolted into place, but this would mean the screen has stress in it, so I'll probably keep going and get it as good a fit as I can.
Al
Slimy38
posted on 24/8/14 at 07:43 PM Reply With Quote
Last time I bent some plastic I aimed to bend it too far, and accept that it will bounce back a certain percentage. As you already know what you're aiming for, and what you ended up with, you should be able to calculate how far to take it.
With regards to heating, it seemed like it could get relatively hot and pliable without incident. But I didn't have much luck reheating it, that's when things got messy (bubbles and stress cracks from memory). I'm not sure what happens inside but it does seem to be a 'one off'.
I don't know what type of plastic I was heating though, so I suspect your experiences may vary.
