Author: Subject: BEC reverse light switch
MK chippy
posted on 28/5/14 at 11:52 AM Reply With Quote
Hi guys,
Just wondering how others have gone about fitting a reverse light switch?
I've got a reverse box fitted but it doesn't have an internal switch like the quaife, so need to figure out some way of fitting one.
How have you guys gone about it? Any photos would be great!
Was thinking handbrake switch that's pushed when my reverse lever is operated to earth the switch?
Dave
adithorp
posted on 28/5/14 at 12:22 PM Reply With Quote
That'd work. You are allowed a manual switch, as long as it has a dash warning light.
http://jpsc.org.uk/forum/
loggyboy
posted on 28/5/14 at 12:24 PM Reply With Quote
Exactly as you sugguest, a foot/hand brake switch or metal armed microswitch on the revese selector
[Edited on 28-5-14 by loggyboy]
Mistral Motorsport
theprisioner
posted on 28/5/14 at 02:57 PM Reply With Quote
I used a motorbike brake light micro switch on the reverse leaver saves having a warning light. Not difficult to install.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
renetom
posted on 28/5/14 at 04:36 PM Reply With Quote
This is what we did
Reverse switch MNR reverse box
could be applied anywhere.
Good luck
still have some of these microswitches I think.
Rob55
posted on 16/6/14 at 12:15 PM Reply With Quote
£5 microswitch from Maplin, the type with the long thin metal arm, attach is so that it is activate when you push the gear knob, job done
