mortda
| posted on 5/6/14 at 10:31 AM |
AlternatorUpgrade
I'm in the process of upgrading the lights on a Daihatsu Mira 850cc , from the dismal 55/60 watt globes to at least a more realistic out put
,90/100 watt or even possibly the higher 100/130 watt globes.
I've upgraded the wiring, including that,that goes to the plug units and have added high amp relays.
I need to now upgrade the Alternator ( the only info I have on the original is that it's out put is 10amps @ 2500 revs which is too low) to
ensure a constant charging current is being supplied. Can anyone suggest an Alternative alternator, which would fit with out too many hassles
hughpinder
| posted on 5/6/14 at 11:41 AM |
You are increasing the output by up to 70W, so you need about 16A output.
Sorry I cant help with an alternator choice, but just 2 things to consider:
1. In the UK the higher rated bulbs would be illegal on the road - I don't know about New Zealand though. No problem for offroad.
2. One of my friends did this and thats how he found out the reflector/light enclosure are plastic- they melted from the heat of the bulbs.
Best of luck
Hugh
AdrianH
| posted on 5/6/14 at 04:43 PM |
Don't forget that there is usually a big difference between alternator revs and engine revs due to the differences in pulley sizes, so an
engine at 2,500 could mean an alternator at around 4,000 or higher.
Adrian
Why do I have to make the tools to finish the job? More time then money.
big-vee-twin
| posted on 5/6/14 at 06:32 PM |
What about a Diahatsu Charade alternator have 40amps output and they are tiny?
http://www.triangleltd.com
mortda
| posted on 5/6/14 at 10:44 PM |
Alternator Upgrade
Thanks for all the information folks..
I realize the problems with the new plastic lenses being prone to melting and therefore the 100/130 watt bulbs would be out of the question, they
are still available here as there are still a lot of older cars with the glass lenses are on our roads (The Americans use to call NZ the
"Museum on Wheels" even the 90/100 watts could at least cause yellowing of the lens and therefore will be considering ducting cool air
from behind the grill to the light's envelope
As for the alternator output, the only information on it that I have, was that it produced 10 amps at 2500 revs ( I have done a quick measure on
the pulley sizes and the ratio is around 2.5:1 which means that if the current alternator if the specs I have are right that the engine revs would
probably be at Idle and the alternator output would likely to be at Idle speed) So,I would suppose the final maximum out put would depend on what the
regulator would allow.
I wondered about the Charade alternator as to whether it would be appropriate and will check into it .
Once again ,thanks Folks for the responses they are very much appreciated
mortda
Scuzzle
| posted on 6/6/14 at 12:08 AM |
Try an uprated standard wattage H4 bulb like Osram Nightbreakers as they do give off better light, Euro Car Parts are usually good for a cheap deal on
these. As for your alternator check out Diahatsu Charade, Suziki Swift, Alto etc. Everything with the small Nippon Denso alternator fitted, if you
can find one with the same fitment as you have already these come in 40 and 50 amp versions.
