Author: Subject: After a spring, any ideas?
killerferret666
posted on 10/6/14 at 09:27 AM Reply With Quote
I'm after a spring for the throttle pedal which is stronger / more resistant.
Now to describe the spring.
Imagine a spring coil with 2 straight ends. so if you had a wire left a straight bit, wrapped it round your finger 5 times then had another straight bit. it would look like that. A bit like a U with a circle at the bottom.
Anyone got ideas on the type of springs name and where i could get one.
Building DDR GT4
Miami Gt4 Blog - Click Here
MP3C
posted on 10/6/14 at 09:41 AM Reply With Quote
Pretty sure you mean a Torsion Spring.
Quick search on ebay and you can get 20 (various sizes) for under a tenner. Im sure if you search for the right one you could get it for a couple of quid.
Here is the 20 LARGE MEDIUM TORSION SPRINGS ASSORTMENT ASSORTED 10 PAIRS VARIOUS MIXED TS24
Matt
killerferret666
posted on 10/6/14 at 09:43 AM Reply With Quote
Matt
cheers Bud,
that's exactly what I meant
So much easier when you know the type of spring, i tried ebay with a search of spring
Building DDR GT4
MP3C
posted on 10/6/14 at 09:47 AM Reply With Quote
I think we have all been there
Matt
The Black Flash
posted on 10/6/14 at 10:31 AM Reply With Quote
Yep, knowing the name of the <thingy> you want is half the battle!
HappyFather
posted on 10/6/14 at 11:17 AM Reply With Quote
I'm very interested on this topic! My throttle peddle only movement back is from the bike engine spring, near the carbs, on the other side of the accelerator cable...
How would you go about putting the "U with a curve" spring on a throttle peddle? Pictures, please?
I was thinking about a straight spring (like the top two on the 2nd column from the left) and put one end on a hole through the peddle and the other through a hole on the peddle pivot casing.
Thank you for ideas on this! Cheers,
HappyFather
mookaloid
posted on 10/6/14 at 11:40 AM Reply With Quote
I think it is important to ensure that the return spring at the carb end is adequate too. Personally I would be adding springs at that end to ensure that the throttle closes if the original one breaks for some reason.
That's what scrutineers look for anyway.
Slimy38
posted on 10/6/14 at 02:35 PM Reply With Quote
This pic shows how it might fit together;
The hooked end of the torsion spring (6) goes behind the pedal arm (1), and the straight end presses against the mount (7).
But as mentioned, might be better replacing the carb end spring.
[Edited on 10/6/14 by Slimy38]
killerferret666
posted on 10/6/14 at 02:51 PM Reply With Quote
Ive got an OBP pedal im adapting which is a floor operated pedal.
Just so I'm clear on why i'm doing it, I have a EFI turbo'd engine and have a throttle position sensor built into the intake as well so changing the spring in this area for me is not really an option.
when I had to set up the throttle position sensor I had a tolerence of 0.2mm!
Building DDR GT4
Sam_68
posted on 10/6/14 at 07:23 PM Reply With Quote
This might be a useful company to know about:
http://www.springmasters.com/index.html
