Author: Subject: Attaching Windscreen to pillars
FlansS14
posted on 12/6/14 at 08:16 AM Reply With Quote
Morning, what is the correct way to attach the screen frame to the pillars... I have done a little research and most just use self tappers (2 each side)
Is it just me or does that seam a little "unsafe" at 100mph+ (Autobahn)
Why didn't i just make it simple!
Macbeast
posted on 12/6/14 at 08:27 AM Reply With Quote
Mine has four, I think 5mm, bolts each side coming through from the inside passing through the supports with domed nuts on the outside
windsceen fix
windsceen fix
[Edited on 12/6/14 by Macbeast]
steve m
posted on 12/6/14 at 09:51 AM Reply With Quote
Mine has 3 of 5mm x10 mm counter sunk screw each side, and has never caused a problem yet
whitestu
posted on 12/6/14 at 09:56 AM Reply With Quote
M5 bolts on mine.
Stu
Macbeast
posted on 12/6/14 at 10:41 AM Reply With Quote
Yes, prob 5mm
snapper
posted on 12/6/14 at 01:22 PM Reply With Quote
I inserted ally rivnuts into the frame from inside, drilled frame supports to the size of the exposed rivnut then filed rivnut back to just below surface of screen support so nuts would countersink
Added angle to rear of screen so screen can't be push back
I eat to survive
I drink to forget
FlansS14
posted on 13/6/14 at 09:33 AM Reply With Quote
Are your M5 bolts just self tapping and screwed into the windscreen surround. Or is it better to drill and tap the frame before fitting the glass..
