Author: Subject: Hella 55mm Light Connectors
Furyous
posted on 13/6/14 at 12:44 AM Reply With Quote
I'm using some Hella 55mm style rear lights but I'm having trouble finding connectors for them. Two of the lights are actual Hella products, and the connection is a junior timer but with the two pins in a T shape instead of parallel ( - - ). I can only find junior timers with parallel connections.
The other lights have this connection:
I could just use spade crimps but I'd quite like to do it properly.
Any pointers on where to find the right connections?
omega 24 v6
posted on 13/6/14 at 06:10 AM Reply With Quote
Not much help but I've worked with a lot of hella products and never seen a connector like that. Are the lights new?? I suspect if not then the connector would have come with them when they were new.
Got a link to the actual lamps?
Furyous
posted on 13/6/14 at 07:46 AM Reply With Quote
Only two of the lights are actual Hella brand. The ones in the photo are the same style but a different brand. They were all bought second hand with no connectors.
They're the same style Rob Collingridge is using:
http://www.robcollingridge.com/kitcar/design/lighting/
ken555
posted on 13/6/14 at 08:03 AM Reply With Quote
Looks like a Dean connector as used in radio control batteries
http://www.rcmodelcentre.co.uk/deans-connectors/cat_350.html
blakep82
posted on 13/6/14 at 08:04 AM Reply With Quote
I'd contact hella asking them. I did for a set of lights I bought and they sent me a set of connectors free of charge
________________________
loggyboy
posted on 13/6/14 at 08:24 AM Reply With Quote
How big are the spades?
Could just be the basic 2 pin T spade connectors:
Motorcycle Electrical Multi-Connector 6.3mm 2 way pin T
Mistral Motorsport
