Author: Subject: busa power commander
ludobenc
posted on 16/6/14 at 08:01 AM Reply With Quote
Hi.
i have to install a power commander on a busa gen 1 engine.
i found some infos about that pc3 differs from years of engines: 99-01 is a version and 02-07 another.
really? what's the difference?
the problem, obviously, is to find the year of my engine..
sotty for my english, i'm italian
http://www.youtube.com/user/LudoBenc
theprisioner
posted on 16/6/14 at 11:17 AM Reply With Quote
I have a Gen 1, as far as I know the PC V will also work Gen 1 engines (I have a PC III USB). Gen 2 Engines have a Oxygen sensor which I assume you just map out if not needed. PC's are mainly a fuel delivery/engine revs remapping function. The main issue for you is the Engine wiring connectors which are different on Gen 2. When buying a PC V I assume you have to specify this.
I apologise in advance if I am talking sh1t.
[Edited on 16/6/14 by theprisioner]
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
ludobenc
posted on 16/6/14 at 12:33 PM Reply With Quote
but my problem isn't gen1/gen2
i'm asking if there are 2 version of power commander 3 for gen1 engine:
-one for 99-00
-anothere for 01-07
i hope to be more clear
theprisioner
posted on 16/6/14 at 01:22 PM Reply With Quote
IU had a search on google for "Hayabusa Gen 1 Power Commander 3 options" the results were inconclusive it appears as if there is more than one connector option. The safest thing would be to email DynoJet. I doubt there is more variation other than the connectors.
ludobenc
posted on 16/6/14 at 01:38 PM Reply With Quote
i think the same..
but here is there a confirmation on the 2 gen1 products:
http://www.locostbuilders.co.uk/viewthread.php?tid=170622
theprisioner
posted on 16/6/14 at 10:36 PM Reply With Quote
Link not valid cannot read?
ludobenc
posted on 17/6/14 at 06:44 AM Reply With Quote
strange. search "hayabusa power commanders".
cosmick
posted on 17/6/14 at 08:02 AM Reply With Quote
There is a difference in the style of multi plug used to differentiate between early and later Gen 1 engines. Early engines had a Square Plug, later ones had a Round Plug. If you don't know the year of your engine, you just need to look at the style of plug. I think the change occurred around 2002. So pre 02 engines should have a square plug at the position where the harness attaches to the injector harness.
Hope this helps.
If it can't be fixed with a hammer then its probably an electrical problem.
ludobenc
posted on 17/6/14 at 08:34 AM Reply With Quote
Hope this helps.
thank you!
