Snuggs
| posted on 22/6/14 at 09:30 AM |
Type 9 dis-assembly problem
Trying to remove the main shaft from the intermediate housing.
Manual say to remove the circlip and then drive it out with a soft mallet.
Circlip has been removed and I have attacked it with various hitting implements but it has only moved 4 mm.
Any suggestions would be appreciated.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
| posted on 22/6/14 at 11:44 AM |
A bigger hammer?
Snuggs
| posted on 22/6/14 at 12:04 PM |
quote: Originally posted by rusty nuts
A bigger hammer?
Cheers Mel
| posted on 22/6/14 at 01:18 PM |
Your welcome. Are you sure you have released everything needed to drop the main shaft such as dropping the lay gear which needs lowering before
removing the main shaft? I have possibly got an old Sierra manual which covers the gearbox, will have a look for you
