Author: Subject: Duratec first start only running on 3 cylinders
TrophyJem
posted on 29/6/14 at 01:42 PM Reply With Quote
I started my duratec for the first time yesterday.
It started first time but its only running on 3 cylinders.
I've checked the spark and that seems ok.
I swapped the injector connectors over on that bank, but still that same cylinder does not run.
Injector resistance measures the same as the others.
So I'm guessing it could be a faulty Injector?
Any other ideas?
Andy S
posted on 29/6/14 at 02:16 PM Reply With Quote
Squirt some fuel down the throat manually if ITB's that will tell you - also if the exhaust is stone cold then that will indicate something definitely wrong or if its actually warm but cooler than the others then that will give you something else to think about.
sdh2903
posted on 29/6/14 at 02:53 PM Reply With Quote
Pull injector and see if it's squirting into a coke bottle? Or swap with one of the other injectors to see if the fault follows it
ashg
posted on 29/6/14 at 04:21 PM Reply With Quote
no1! is the plug getting wet? if not give the injector a tap it may be a bit sticky.
if the plug is wet then its either a spark issue or something mechanical. have you done a compression check?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
pjay
posted on 29/6/14 at 04:48 PM Reply With Quote
I've had a similar situation and was a sticking injector (wire up 12v and listen for it to click). Just to check are you happy with compression on that cylinder (remove all other plugs and turn over by hand).
TrophyJem
posted on 29/6/14 at 05:10 PM Reply With Quote
Cheers for the pointers.
I've not had chance to look at it today as moving my son home from uni.
So its been a day of worrying about it
posted on 29/6/14 at 06:53 PM Reply With Quote
A mechanics stethoscope should let you hear the injectors working, if you pick one not working check it is getting a signal using a NOID light which is really just a 12v LED.
As already said a compression check is a good idea.
TrophyJem
posted on 30/6/14 at 08:31 PM Reply With Quote
Well tonight I got it running on all 4
The throttle body was closed a little more than the other 3 and I had it set so rich that that cylinder was flooding.
Leaned it up a bit and all seems good. I originally set the fuel on the megasquirt to 440cc injectors and the pressure to 3 bar but that seems way to rich.
Doesn't run particularly smooth but that's for Dale at Bailey Performance to sort for me when he gets it on the rolling road.
Just a small coolant leak to sort.
