Author: Subject: Bloody Electrics!!!!
pekwah1
posted on 9/7/14 at 10:33 AM Reply With Quote
Hi Guys,
So got most of the other stuff sorted on my car, but for some reason my right hand indicator now comes on when i brake or reverse.... Checked the continuity of the cables at the rear and am seeing continuity between the rear lights, rear brakes, indicators and reverse.
All run on seperate switched live feeds. Initial thought was cabling has got mangled down the tunnel but seems to be perfectly intact. Just ripped the dash back off and looks like i'll be stripping down all the wiring (again).
Just thought i'd have a moan and haven't said much lately
Grimsdale
posted on 9/7/14 at 10:45 AM Reply With Quote
did you check the earth at the light unit? you will get some continuity through the filaments of the bulb, but that should give you a measurable resistance.
If your earth is ok, take the bulbs out and check again
[Edited on 9/7/14 by Grimsdale]
stevebubs
posted on 9/7/14 at 10:51 AM Reply With Quote
bad earth would be my guess - when one of the lights is on, the power is being earthed through another..
pekwah1
posted on 9/7/14 at 11:23 AM Reply With Quote
that's what i thought, i did remove most of the bulbs and still had continuity, but not all of them.
I'll whip out every bulb and try again.
If that fixes it, does that mean i potentially just have a dodgy bulb?
pekwah1
posted on 9/7/14 at 11:24 AM Reply With Quote
Sorry just re-read, i'll double check the earths again as well, although appeared to be ok when i looked last.
Daddylonglegs
posted on 9/7/14 at 02:19 PM Reply With Quote
Another vote for earth issue
Boltsy
posted on 9/7/14 at 02:48 PM Reply With Quote
Bad earth
Limitation starts where the visions end - Jimmy Johnson
posted on 9/7/14 at 02:49 PM Reply With Quote
Yes, bad earth, try running an earth from each circuit back to battery or engine/gearbox as well as to the chassis at the rear.
DW100
posted on 9/7/14 at 03:13 PM Reply With Quote
Check the obvious, single filament bulb in a 2 filament holder? See it all the time on customers cars!!!
Also see lots of cheap crap bulbs, that are shorting out internally or just plain poorly assembled
[Edited on 9/7/14 by DW100]
pekwah1
posted on 9/7/14 at 05:01 PM Reply With Quote
It turns out you guys are very clever and it was indeed....................
.................... a bad earth!
Thanks for the help and suggestions, was starting to pull my hair out!
Really glad i stripped off the tunnel top, dash etc for a single cable that's in the boot!!!
