Author: Subject: Coolant Problem
S1502
posted on 18/7/14 at 12:39 PM Reply With Quote
Coolant Problem
Hi guys took my tiger out or a spin yesterday and the temp gauge went wild. hit 120c and my coolant exploded out everywhere.
thought it may have been an air lock as I replaced a hose at the weekend but I have refilled the coolant and tried to burp the system and it just keeps boiling out until there is nothing left.
I'm running a 2ltr silvertop zetec on a mondeo ecu.
Had thought it may be the temp sensor but i'm not sure how to get at that so any help would be much appreciated as i'm currently a bit stuck for ideas.
cliftyhanger
posted on 18/7/14 at 12:57 PM Reply With Quote
Try taking the thermostat out, they can go faulty. Other than that could be HGF unless there is a blockage somewhere?
When cold what happens when you start the engine? cap off expansion bottle?
Has the car been standing unused for a while?
S1502
posted on 18/7/14 at 01:01 PM Reply With Quote
when cold engine starts fine. doesn't start rough at all just like normal. its been in use without issue.
Im just trying to find out how I remove the thermostat to take a look at it any ideas?
Im praying its not HGF.
adithorp
posted on 18/7/14 at 01:03 PM Reply With Quote
If it's boiling then it'snot just the temp sender isn't telling porkies.
It's over heating either because (in order of likelyhood)...
1. There's an air-lock stopping proper circulation.
2. The fan isn't working (should only be an issue if it only happens when stationary)
3.The stat' is stuck shut and no water is being circulated.
4. The water pump isnt puming water around (impeller failed?).
5. The rad' is blocked.
6. The head gasket has failed and compression gas is getting into the coolant (pos'as a result of 1,2,3,4or5)
http://jpsc.org.uk/forum/
S1502
posted on 18/7/14 at 01:15 PM Reply With Quote
1. There's an air-lock stopping proper circulation. Tried squeezing all pipes nothing seems to happen
2. The fan isn't working (should only be an issue if it only happens when stationary) fan kicks in at 92c
3.The stat' is stuck shut and no water is being circulated. Don't no how I would check this.
5. The rad' is blocked. This isn't blocked ive removed the cap and water pours out when engine running upto temp
Smoking Frog
posted on 18/7/14 at 01:18 PM Reply With Quote
Is it a coincidence that a hose was replaced? Purge the system of air. Be 100% sure it's not that before diagnosing a more serious problem.
S1502
posted on 18/7/14 at 01:21 PM Reply With Quote
literally had it running about 15 times with coolant in and its just flowing out the top everytime really lost for how I can try to get the air out if it is that.
S1502
posted on 18/7/14 at 02:58 PM Reply With Quote
just removed stat appears it has been stuck shut so cut it to let it flow freely and problem looks to be solved off to buy a replacement tomorrow
adithorp
posted on 18/7/14 at 03:55 PM Reply With Quote
Nice one. Fingers crossed it'snot caused any other issues.
Be sure the new stat has a tiny air bleed hole it that lets any trapped air through. Not all new stats have oneand if it doesn't drill one in the base plate (2mm will be enough).
