Author: Subject: Tips on connecting Haynes pedals to throttle and clutch cables
novicebuilder
posted on 26/7/14 at 05:33 PM Reply With Quote
I am searching for a suitable connector for my cables to the Haynes roadster pedals. I have looked at various clevis pins and other assembles but would be grateful for any tips of products others have found work well.
Donor Sierra clutch cable has a soldered nipple on the end and is too long. Throttle cable has a plastic button on the end and is correct length.
How to decide the correct length to cut my donor clutch cable and then what should I fit on the end (solderless nipple?) Should I fit a cable adjuster on it for fine adjustments?
davidimurray
posted on 26/7/14 at 06:13 PM Reply With Quote
From memory I used a 1300? Capri clutch cable that was perfect for my pinto/type 9 combo. For throttle I used a universal cable kit and just clamped the cable under a couple of washers.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
novicebuilder
posted on 26/7/14 at 08:47 PM Reply With Quote
Are you talking about the Universal cable repair kit from Car builders solutions?
Great build diary photos. Well done on such a good job. Car looks great and there are platy of really useful details which I can compare to my build. Thanks.
davidimurray
posted on 26/7/14 at 09:58 PM Reply With Quote
From memory I used one of these http://www.venhill.co.uk/Cables_-_Components_Kits/Universal_Cable_Kits/U01-4-100_UNIVERSAL_THROTTLE_CABLE_SINGLE.html . At the pedal box end I welded a tube at an angle with a plate across it with a tapped hole to match the adjuster. So at the pedal box I have the screw adjuster and at my bike carbs I have a plain nipple.
Glad you like the photos, I could never find details when I was building mine so tried to document as much as possible.
davidimurray
posted on 26/7/14 at 10:05 PM Reply With Quote
Some more info on clutch cable - http://www.haynes.co.uk/forums/showthread.php?t=7005&highlight=capri
