Author: Subject: MX5 gearbox sensors !
cb500t
posted on 4/8/14 at 07:33 AM Reply With Quote
The box has 2 'sensors' one with red wires one with blue,what do they do and could I remove the 'red' one as its causing installation problems : (
rdodger
posted on 4/8/14 at 07:48 AM Reply With Quote
One is the reverse switch, the other a neutral switch. Sorry I can't remember which way around they are.
cb500t
posted on 4/8/14 at 07:55 AM Reply With Quote
It would be soooooo nice if it was the neutral switch !
rdodger
posted on 4/8/14 at 07:57 AM Reply With Quote
Just check the continuity to see which is which.
cb500t
posted on 4/8/14 at 10:15 AM Reply With Quote
Box is out of MX and sitting in my chassis...
BigMac
posted on 4/8/14 at 10:37 AM Reply With Quote
Hopefully these may help?
Clicky
rdodger
posted on 4/8/14 at 02:05 PM Reply With Quote
You should still be able to test continuity with a meter.
Slimy38
posted on 4/8/14 at 03:55 PM Reply With Quote
Blue is on top of the gearbox and is the idle, red is over the left hand side and is the reverse. I've just done what rdodger suggested and stuck a multimeter on blue while I used a metal bar to shift the gears (I also have my engine sans car at the moment)
cb500t
posted on 4/8/14 at 04:31 PM Reply With Quote
I thank you all....
