Author: Subject: Reccomend me some fuel pumps!!
edthedrummer
posted on 12/8/14 at 04:39 PM Reply With Quote
Howdy all,
Starting to plan my fuel system now, starting with an alloy racing fab locost tank, with an/jic fittings, to an alloy racing fab 1litre swirl pot, again with jic fittings instead of push ons. It's for a duratec install. I can source a fuel rail with jic fittings easily enough, but what fuel pumps, both lift and high pressure do people reccomend, that can be fitted with an/jic unions to accept proper fittings?
Thanks for your help!!
Ed
FuryRebuild
posted on 12/8/14 at 05:33 PM Reply With Quote
I went for a nissan skyline pump, from fuelpumpsonline.co.uk.
It's an in-tank pump and a high-pressure one, so it shouldn't need a low list pump and swirl pot to feed the injectors. It's also rated hugely for the HP I require, so should be well over-specced.
I paid less than £100 for it, IIRC.
There's a picture of it here (click me).
M
www.furyrebuild.co.uk
Mr C
posted on 12/8/14 at 07:11 PM Reply With Quote
I'm also looking for a lift and high pressure pump, same setup as OP. Using an Elise Tank so not keen on going direct to fuel rail from tank, especially round left handers.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
jeffw
posted on 12/8/14 at 07:36 PM Reply With Quote
Bosch 044 HP Pump and the Weber Carb pump. The Weber is meant to be almost silent which is much better than the noise my Facet pump makes.
Paul Turner
posted on 13/8/14 at 01:08 PM Reply With Quote
Mine uses a Facet red top as the lift pump (same pump I used when it had carbs) and a Sytec high pressure pump which I bought cheap from a friend of a friend who was changing to an in tank pump.
10 years on no issues.
