Author: Subject: Ebay exhaust looked good in the pictures, but then.....
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 10/9/14 at 07:40 PM Reply With Quote
Ordered one of these from ebay.
6" dia, 18" long, 2.5" pipe down the middle. Thought that would be good, no sharp edges for IVA etc.
See nice smooth edges.
But this is what turned up!
Look at the edges on that!!
Spoke to the company who said, "yeah, we changed the design, not had issues on kitcars before". Wasnt best pleased. The have now changed the picture that appears in the search listing, but the original pictures are still in the listing!
Universal Silencer 6"' 2.5"' x 18"' Exhaust Stainless Steel Back Box
mackei23b
posted on 10/9/14 at 07:48 PM Reply With Quote
An exhaust guard would cure it, that said..... the item not as described so if your not happy raise a dispute on that basis?
Ian
phil m
posted on 10/9/14 at 09:47 PM Reply With Quote
It's clearly not the one in the original pic, but Wouldn't this be ok for IVA?
I've been through 2 SVAs and they weren't concerned with the silencer edges as "you would burn your self, rather than be affected by the edges"
Both times they did apply common sense when possible
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
posted on 10/9/14 at 09:59 PM Reply With Quote
The main problem I have is finding the right size internal pipe, I went for 2.5" because it looked better, most reasonably priced exhausts are 2". The box was about £55 delivered so not the most expensive.
Is the general opinion that it will be ok for iva then? Thought the blunting of edges was in case of crash etc.
40inches
posted on 10/9/14 at 10:18 PM Reply With Quote
At my IVA (last year) they let me cover the edges with edge trim (after the silencer had cooled down )
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
posted on 10/9/14 at 10:22 PM Reply With Quote
Can see me having to put some on.
Did yours not fall off again after the test?
Mr Whippy
posted on 10/9/14 at 10:42 PM Reply With Quote
polymax and a few others do silicon edging that can take 200 - 350 degs which is probably ok for the edges of the silencer
Chris_Xtreme
posted on 10/9/14 at 10:47 PM Reply With Quote
my robin hood exhaust, like yours failed SVA.. trim wasn't permitted as would melt off, I had to bend a bit of ali with edge trim on and clamp in place to make a guard.
owelly
posted on 10/9/14 at 11:13 PM Reply With Quote
Cut a hole in a stainless dog bowl. Slip it over the pipe to make an end cover.
http://www.ppcmag.co.uk
907
posted on 11/9/14 at 07:13 AM Reply With Quote
The materials alone would come to more than that, assuming 304 ss & quality wadding.
Sorry if that offends but it is the truth.
Paul G
r1_pete
posted on 11/9/14 at 07:32 AM Reply With Quote
You ordered a silencer which was pictured as a smooth unit, with no protruding welded lips, what turned up is not what was pictured, no amount of trim or covers will look as neat as your original intention. I would definitely go for returning it with a full refund and return postage, it is not as described, and not fit for the purpose you intended going by the original description.
splitrivet
posted on 11/9/14 at 09:17 AM Reply With Quote
Yep had the same issue, saucepan lid is what you need take the knob, off holesaw the centre whack it in off you go.
Took me ages the find the right size though, visiting various cheapo shops with a tape measure measuring saucepan lids.
Bob
[Edited on 11/9/14 by splitrivet]
40inches
posted on 11/9/14 at 02:00 PM Reply With Quote
He said to take the MK up to the car park, wait till the silencer cooled before putting on the trim, while he made out the pass certificate
43655
posted on 11/9/14 at 05:49 PM Reply With Quote
you can definitely demand a refund or whatever based on it not being as shown, there are laws against that sort of stuff.
However could you not cut the lip off and re-weld the edges together (assuming it's on the flange that te two parts are joined at)
Small reel of 304 MIG wire should do.
However if you send it back, I [ebay=250879771966]Universal Silencer 4"' 2.5"' x 14"' Exhaust back box Stainless Steel | eBay
ntitled Docu
snapper
posted on 11/9/14 at 07:36 PM Reply With Quote
I passed with edge trim and it did not burn after I left it on
It was bloody loud though, now have a Paul Gooderham (907) 3" special
Its loverly
I eat to survive
I drink to forget
JacksAvon
posted on 12/9/14 at 07:24 PM Reply With Quote
+++ for Paul Gooderham exhaust.
97db at 6250rpm static at Silverstone Interntional Allcomers race last weekend.
