jwhatley
| posted on 11/9/14 at 01:24 PM |
Anyone know where to get one of these?
So its from the end of the CV joint on a Sierra Lobro Driveshaft bolt on hub. Mine has a split in it some how and is chucking grease out. I
can't find one for love nor money on its own, only with the CV joint.
Has anyone replaced just the boot/metal cap before? If so where the hell did you find them?
I think its one of these: http://www.jandrcvjoints.co.uk/ford-sierra-cosworth-4wd-rear-drive-shaft-cv-joint-boot-kit-100mm/
From what i can see its called a Protective Cap, Ford number 1495775 or 1505915.
See Pics
John
mookaloid
| posted on 11/9/14 at 01:33 PM |
Where is the split? could it not be welded/brazed?
jwhatley
| posted on 11/9/14 at 02:02 PM |
Its on the flange, its where its previously been hit with a cutting disc removing a seized bolt and has corroded through. Welding it is not really an
option as its super thin and pretty corroded already.
40inches
| posted on 11/9/14 at 02:07 PM |
They come with the CV joint kit http://www.jandrcvjoints.co.uk/ford-sierra-constant-velocity-cv-joint-boot-kit-100mm-brand-new/
loggyboy
| posted on 11/9/14 at 02:08 PM |
I may have a couple of used ones. Will check condition.
EDIT
FORD ESCORT / SIERRA COSWORTH 4X4 REAR DRIVESHAFT CV JOINT GAITER BOOT KIT
[Edited on 11-9-14 by loggyboy]
Mistral Motorsport
jwhatley
| posted on 11/9/14 at 02:10 PM |
Yeah, i suppose i should stop being so tight. I don't want to buy a new CV joint as i don't need it!
jwhatley
| posted on 11/9/14 at 02:46 PM |
EDIT
Ahha! Spot on that man. They look like the ones!
John
jacko
| posted on 11/9/14 at 06:23 PM |
I have just put two in the skip today if you want them there yours for the price of the post
i will go and get them out the skip now
jacko
You seem to have the half moon washers missing on the photo of the drive shaft
[Edited on 11/9/14 by jacko]
snapper
| posted on 11/9/14 at 07:29 PM |
eBay
Cheap
I eat to survive
I drink to forget
