Author: Subject: m.n.r reverse box
ianminki
posted on 5/10/14 at 12:06 PM Reply With Quote
m.n.r reverse box
hi all
help needed pls. I have fitted to my stylus a mnr reverse box which has been fine except for been noisy in reverse. the problem I am having at the moment is when out in car it has started to jump out of forward gear when on the move. the question I would like to ask is is there any adjustment at all to the lever as I cannot see anything wrong or loose, apart from some backlash all seems fine
regards ian
renetom
posted on 5/10/14 at 05:13 PM Reply With Quote
Hi
Yes there is adjustment the collar on the top but be very careful.
Our lost drive on the road
sent it back to MNR they replaced a spring inside with a stronger one
was fine after that
good luck.
René
Reverse switch MNR reverse box
ianminki
posted on 7/10/14 at 07:08 AM Reply With Quote
hi
thanks for the reply . box now out and on removing the top found that the top gear cog has been scoring the inside of the box side. the spring looks ok but loose so taking it back to mnr for repair
thanks againe regards ian
