Boylers11
posted on 13/10/14 at 09:42 PM |
Heads up for keeping your regulator rectifier cool
Just got one of these from Maplins for £5. The heat sink is 2" thick and the fan is roughly 2.5" diameter..
A complete bargain I thought and decided to share........
mcerd1
posted on 14/10/14 at 07:28 AM |
socket A CPU's are so old I'm amazed any shops still have them
I must have at least one of them sitting in old scrap machines and several others of similar size for free...
Boylers11
posted on 14/10/14 at 07:41 AM |
Lucky you. Just thought I'd help fellow BEC builders. No need to be an a**hole about it
CosKev3
posted on 14/10/14 at 08:09 AM |
How hot do they get?
Daddylonglegs
posted on 14/10/14 at 08:45 AM |
Very!
I had to have a similar thing on my old Honda VFR 750. A common fault is the regulator overheating and frying the battery. I cured it by using heat
sink compound between the regulator and the frame, and fitting a 12V CPU cooling fan to the top of the regulator. It's surprising how hot CPUs
etc can get.
[Edited on 14/10/14 by Daddylonglegs]
40inches
posted on 14/10/14 at 09:15 AM |
I did something similar,a 90mm fan from PC World, although it cost twice as much at £10.
CosKev3
posted on 14/10/14 at 11:25 AM |
Very!
etc can get.
Ok cheers,have to think about positioning mine in the next couple of days as I chop my loom down
bigfoot4616
posted on 14/10/14 at 12:37 PM |
i know honda's are well known for failing, don't think its as much of a problem on r1's though.
still worth a bit of thought when it comes to positioning of it.
posted on 14/10/14 at 02:48 PM |
A lot of the newer bikes (including later R1s) have MOSFET based regulators that run significantly cooler and are very reliable so no extra cooling is
needed. The earlier Honda regulators had a terrible thermal design, quite surprising given Hondas reputation of engineering excellence.
matt_gsxr
posted on 15/10/14 at 10:03 AM |
+1 the MOSFET ones don't get hot at all.
http://jpsc.org.uk/forum/
