Author: Subject: Odyssey battery for locost
Streetfighterpete
posted on 19/10/14 at 01:00 PM Reply With Quote
Hi all, anyone ever fitted an Odyssey dry cell battery to their locost? If so what size did you fit? I'm running a 2.0 Zetec blacktop engine.
Pete
big-vee-twin
posted on 19/10/14 at 01:42 PM Reply With Quote
PC 680 works fine.
http://www.triangleltd.com
Ross Carter
posted on 19/10/14 at 02:23 PM Reply With Quote
PC680 starts high compression 2100 pinto no problem.
Streetfighterpete
posted on 19/10/14 at 02:58 PM Reply With Quote
Hi guys,
Thanks for that - just what I needed - I was looking at the PC1200 which would probably have been a bit of an overkill.
serieslandy
posted on 19/10/14 at 03:16 PM Reply With Quote
PC680 on mine as well.
1.8 Pinto. I didn't know what to buy and it seems much better than a normal acid battery.
Ben_Copeland
posted on 19/10/14 at 10:34 PM Reply With Quote
Just don't let them discharge and/or get too cold for long periods.
Battery optimiser is a good idea.
Ben
Locost Map on Google Maps
Enter Your Details Here
stevebubs
posted on 19/10/14 at 11:12 PM Reply With Quote
PC680 for me, too - Blacktop 2.0 zetec on throttle bodies..
[Edited on 19/10/14 by stevebubs]
RK
posted on 20/10/14 at 04:02 AM Reply With Quote
They don't last very long, but maybe that is related to charging properly. I had two, and ended up with a bike battery.
Ross Carter
posted on 20/10/14 at 03:08 PM Reply With Quote
Re PC680
I was informed when I purchased mine to install a battery cut off switch as they can be drained quite quickly due to being connected to a load, I also connected a plug to the battery as to allow a smart charger to be connected easily
