Author: Subject: Duratec - Oil Pressure Switch Connector
davidimurray
posted on 31/10/14 at 09:48 PM Reply With Quote
Does anybody know where I can get a new wiring plug for the oil pressure switch used on the Duratec? One came with my engine, but the wire was cut off flush.
Connector looks something like this -
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
big_wasa
posted on 31/10/14 at 09:53 PM Reply With Quote
New no.
You could lift the yellow bit and remove the pin, carefully open up the crimp and add a new wire. solder and rebuild.
It looks like same plug as the blacktop onwards zetec plug.
big_wasa
posted on 31/10/14 at 10:10 PM Reply With Quote
Just had a look in the garage and I have spares so if you cant get a new one, send me a self addressed jiffy bag and I will send you one.
davidimurray
posted on 31/10/14 at 10:35 PM Reply With Quote
Thanks for the offer - will see how I get on - found these - http://www.simtekuk.co.uk/product.php/1_way_sealed_sensor_connector_b_cfp/?k=:::5830476
davidimurray
posted on 31/10/14 at 10:39 PM Reply With Quote
And these in the US annoyingly - only $1.81 !!!!!! http://www.corsa-technic.com/category.php?category_id=103
big_wasa
posted on 1/11/14 at 09:32 AM Reply With Quote
Yep, but I guess postage wont be as cheap and easy.
davidimurray
posted on 2/11/14 at 06:49 PM Reply With Quote
Postage is pretty cheap according to their website.
Anyway been doing some more research, looks like a lot of these connectors are Tyco/AMP units in the SSC range. Some good info here - http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Specification+Or+Standard%7F114-8004%7FG%7Fpdf%7FEnglish%7FENG _SS_114-8004_G.pdf%7F184042-1
davidimurray
posted on 5/11/14 at 07:22 PM Reply With Quote
Oil Pressure switch is a Tyco/AMP unit, SSC Model, Part no - 184042-1
You can buy from Mouser UK or order Free samples from TE Connectivity
Cam/Crank sensors are also the same series and you can get them the same way
