Author: Subject: Cleaning exhaust ports
omega0684
posted on 3/11/14 at 06:24 PM Reply With Quote
Hi guys,
Hope you are all well? It's been a while since I've posted but I'm finally back In the garage. I just have a quick question regarding exhaust port cleaning, has anyone found a way of cleaning all the black soot/crap on the inside of the port, I need to port the exhaust ports but I know that all my grinding stones will clog up with the amount of soot in there
It feels good to be back!
Alex
posted on 3/11/14 at 07:02 PM Reply With Quote
Gasket stripper lifts carbon easily
davidimurray
posted on 3/11/14 at 07:33 PM Reply With Quote
I used some of these - http://www.toolstation.com/shop/Power+Tool+Accessories/d80/Wire+Abrasives/sd1920/Decarb+Wire+Brush+Set/p53351
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
mark chandler
posted on 3/11/14 at 07:41 PM Reply With Quote
Retire the grinding stones, spend £15 on decent burrs to move the material then some little rotary sanding wheels to tidy up.
perksy
posted on 3/11/14 at 08:26 PM Reply With Quote
Your not going to fiddle with that 'work of art' cylinder head by John Yeomans are you mate ?
OR are you just thinking of matching the exhaust ports to the exhaust manifold you have ?
snapper
posted on 3/11/14 at 08:59 PM Reply With Quote
Pinto's are all cast steel so you can just use dremel sanding tubes and wire brushes to remove it
I eat to survive
I drink to forget
omega0684
posted on 3/11/14 at 09:54 PM Reply With Quote
Hey perksy,
I have upgraded from 42mm and had some 46mm inlets put in! I am blending the inlets back in and just tidying up the exhaust ports as they haven't been touched.
If you thought the old head was good, you wait until you see the new one!
All the best
Alex
twybrow
posted on 4/11/14 at 08:00 AM Reply With Quote
Hey perksy,
All the best
Alex
Are you polishing a turd again Alex?! Drop the boat anchor overboard, and put in a modern lump this winter! Go on, you know you want to....!
mcerd1
posted on 4/11/14 at 08:30 AM Reply With Quote
+1 for the wire brushes
so how much more power ore you trying to squeeze out this time Alex ?
prawnabie
posted on 4/11/14 at 07:38 PM Reply With Quote
Good to see you back on here you tart!
+ 1 with twybrow its time to dump the lead weight!
[Edited on 4/11/14 by prawnabie]
SCAR
posted on 4/11/14 at 08:24 PM Reply With Quote
Small wire brush in one of those cheap mini drills does the job . Leave the valves in to protect the valve seats when doing the combustion chamber.
[Edited on 4/11/14 by SCAR]
