posted on 3/11/14 at 09:32 PM |
Towing a 7 with an A frame
Not your usual 'is it legal' question, as I know it's not! What I'm wondering is how well it works with a car that
doesn't self centre? On my car, if you turn the wheels halfway to lock, the steering doesn't self centre, it tries to turn itself to full
lock. Probably due to too little castor, but would this stop an a frame working properly? I need to possibly pull it 200 miles next week.
rick1962uk
posted on 3/11/14 at 10:10 PM |
watch out as the diff dosent like to be pulled years ago when i had a dolly i always put the drive wheels on the dolly
Ben_Copeland
posted on 4/11/14 at 07:55 AM |
Saw one being towed to Stoneleigh this year on an a-frame, can really comment on the self centring part tho.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
owelly
posted on 4/11/14 at 09:19 AM |
I towed a fwd rally car that had the same issues. It followed fine until the first sharp corner! Then the front wheels spun onto full lock and dragged
the tyres sideways!
http://www.ppcmag.co.uk
jossey
posted on 4/11/14 at 07:58 PM |
As owelly said. Will be fine till a corner or roundabout.
David Johnson
Oddified
posted on 4/11/14 at 08:03 PM |
As already said, without good self centering, forget it.
Ian
HappyFather
posted on 5/11/14 at 09:37 PM |
There are some contraptions used to block the steering by hooking it over to the peddles. If something like this is used, can't the 7 be towed
even if it doesn't self-centre? For all purposes, the steering lock would keep the front wheels straight, no? And would that damage any part of
the car?
steve m
posted on 5/11/14 at 09:47 PM |
What about raising the tyre pressure on the front wheels. just while towing
As this cheat method seems to help some builders with getting through the testing phase
posted on 5/11/14 at 10:01 PM |
It's as I expected then, I'll cross the A frame off the list!
It really is quite poor handling if I'm honest. Dreadful bump steer and anti self centering. Think a visit to procomp is on the cards.
Cheers!
owelly
posted on 5/11/14 at 10:40 PM |
Which car and where is it going?
posted on 6/11/14 at 06:51 AM |
I'm off for another tour of Islay and the kit is coming! Was thinking of towing it up past Glasgow to avoid the motorway. 6.5 hours in a 7 is a
bit much even for a stubborn bastard like me!
owelly
posted on 6/11/14 at 10:33 AM |
You can borrow the trailer I got off you? I'll need a bit of notice so I can change the bearings and give it a once-over!
posted on 6/11/14 at 01:33 PM |
Very kind wellyboot! I'm going to chance it anyway, if it breaks I can always chuck it into a field and get a lift with a mate! Managed to get
as far as Halifax today with nothing falling off so maybe I'll make it all the way!
We're doing 6 distilleries in 2 days!
owelly
posted on 6/11/14 at 01:41 PM |
I did all the ones on the coast in my boat..........not recommended! I think there were eight but I lost count after the first couple!!
RK
I used to tow my 7 with my Audi with an A frame tow bar. I attached the bar to the upper suspension pickup points and had no trouble at all. I had
some magnetic lights for brakes etc, wired to the Audi. Just remember to put the 7 in neutral before you pull away... had to be said.
owelly
posted on 6/11/14 at 02:38 PM |
Incidentally, I have an A-frame that you can borrow....for recovery to a safe place only. I think there's a safe place in Bowmore.
