Boylers11
| posted on 9/11/14 at 06:47 PM |
What's wrong with my rack?
Took my car for an MOT a couple of weeks ago and it failed on a few small bits, one of which was the fact that there was play in the steering rack on
the passenger side.
I've taken the rack off, which I think is Cortina. The drivers side is tight, the passenger side does indeed have a mm or two of play when you
push the shaft towards the rack. I presume this is due to the tie rod, which I have removed from the rack. I've attached a diagram of what it
now looks like and I can't work out what's exactly wrong.
The tie rod physically won't screw further onto the rack unless I become Jeff Capes, yet there's a still a bit of play there. It's
almost as though the spring behind the plastic 'cup' (see diagram) isn't stiff enough?
I'm concerned that if I buy a new tie rod, the same thing will be present.
Help would be great!
adithorp
| posted on 9/11/14 at 07:59 PM |
I'd suspect it's just wear on the ball and/or cup. Probably the only option is replace it.
http://jpsc.org.uk/forum/
Boylers11
| posted on 9/11/14 at 08:09 PM |
I thought wear and tear too, but the ball fits perfectly in the cup. The slack is only present when it's all bolted back together? I'll
look into ordering a new one tomorrow.
Thanks very much
| posted on 9/11/14 at 08:22 PM |
I had exactly that a few weeks back on my mot. Tragically, I can't remember what caused it or what we did to fix it! I had a spare rack, and we
took both apart. I suspect we just reassembled with the spare arm.
Boylers11
| posted on 9/11/14 at 09:01 PM |
I'm tempted to try and screw it onto the rack a tiny bit more to out a bit more tension on the spring, but is it the spring that takes up the
slack by itself?
maccmike
| posted on 9/11/14 at 10:40 PM |
put a washer behind the spring for more tension
| posted on 9/11/14 at 10:54 PM |
You can shim it but it won't be a longterm solution..
That is the Can Gears rack Kiley Clinton make replacement tie-rods for the Escort mk2 version which istr are the same length
[Edited on 9/11/14 by britishtrident]
Boylers11
| posted on 10/11/14 at 12:38 PM |
Thanks for the replies.
I'll maybe try another washer first to shim it out a bit and get it through the MOT and then give Kiley Clinton a call to arrange a new one
Xtreme Kermit
| posted on 10/11/14 at 05:23 PM |
Sadly, this seems a technical discussion about steering gear. I was expecting something else...
steve m
| posted on 10/11/14 at 06:27 PM |
Boylers11
| posted on 10/11/14 at 10:30 PM |
Haha, that was my plan in order to get plenty of people viewing the thread!
