Scuzzle
| posted on 12/11/14 at 08:09 PM |
Brake Union Adapter
Can anyone point me to where I can buy a M10.1 female to a 1/8 NPT male union preferably a 90 deg one. It's so I can make my Goodridge hoses on
my MK1 Fiesta fit some new Wilwood Powerlite calipers I'm fitting.
Took me a fair while to find these standard ones, plenty going the other way round with the threads, not so many the way I need.
http://www.carbuildersolutions.com/uk/brass-union-18-npt-male-to-m10-x-1mm-female
These would put the brake hose outwards though so a 90 deg one would be better.
[Edited on 12/11/14 by Scuzzle]
ste
| posted on 12/11/14 at 08:31 PM |
Here's one but in America
http://www.cbperformance.com/ProductDetails.asp?ProductCode=6636
what if you just got a 1/8 elbow like you found, then fitted that adapter on to it?
Scuzzle
posted on 12/11/14 at 08:50 PM |
Never thought of that, would work fine, cheers
adithorp
| posted on 12/11/14 at 09:01 PM |
As it's a tapper thread could you guarantee a 90' fitting would tighten up pointing the right way?
http://jpsc.org.uk/forum/
Scuzzle
| posted on 12/11/14 at 09:49 PM |
You can usually wrax it round enough to the right way, if it's good and tight fine, if not a layer of PTFE tape or loctite helps.
