Author: Subject: Opinion on design?
killerferret666
posted on 15/11/14 at 04:07 PM Reply With Quote
Opinion on design?
Finally managed to get hold of the spoiler I wanted... Now do I keep the end curves...or chop them off, bad photoshop included! Opinions wanted on what others think. If I chop the curves off obviously the spoiler wouldn't be as wide so not sure it would look right, hard to judge
Building DDR GT4
Miami Gt4 Blog - Click Here
Ugg10
posted on 15/11/14 at 04:19 PM Reply With Quote
With that spoiler I would keep the end plates on. If you want one without end plates I would personally go for one like the noble m12, more gt3 racer look than street cruiser.
[Edited on 15/11/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mookaloid
posted on 15/11/14 at 04:23 PM Reply With Quote
Quite like the end curves
garyt
posted on 15/11/14 at 04:37 PM Reply With Quote
keep the curves imo it looks far better with than without
mark chandler
posted on 15/11/14 at 05:36 PM Reply With Quote
^^^ ditto
steve m
posted on 15/11/14 at 05:38 PM Reply With Quote
I am not a spoiler fan, but with the ends, appear to follow the curvy likes of your car, so keep them
with out the ends, it looks like you have bought a halfords one and stuck it on
just imho !
steve
davidimurray
posted on 15/11/14 at 07:48 PM Reply With Quote
Keep the ends - fits well with the car
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
T66
posted on 15/11/14 at 07:51 PM Reply With Quote
Better with the ends for my eye - blends better with the bodyshell, without it looks too short.
tegwin
posted on 15/11/14 at 07:57 PM Reply With Quote
I like the middle bit following the contours of the car but the ends look a bit too max power... Chop them off and extend the wing to full width and put little vertical winglets to finish the ends. Imho
www.verticalhorizonsmedia.tv
big_wasa
posted on 15/11/14 at 08:16 PM Reply With Quote
keep it curvy
Carbonman
posted on 15/11/14 at 08:21 PM Reply With Quote
What about lowering it a bit and blending the curved ends into the rear wings.
Carbon Copies Ltd
myke pocock
posted on 15/11/14 at 09:11 PM Reply With Quote
Keep the ends and loose those god awful headlights!!!
gremlin1234
posted on 15/11/14 at 09:18 PM Reply With Quote
ditto
killerferret666
posted on 15/11/14 at 09:32 PM Reply With Quote
That would be a complete redesign lol However the headlight covers won't be the same colour of the car when done. This isn't going to be the colour of the car at all, this is just current gel coat. Unless you mean tail lights...then I agree they are a bit dated and at some point in the future will be replaced by LED rings.
I tried resting the rear wing on the arches with same idea about curves blending in, the wing would need to be at least 3-4" wider and for the work in labour time to do just doesn't make economically viable. It would currently blend in just before the bodywork curves so I think would look a bit wrong.
Building DDR GT4
myke pocock
posted on 15/11/14 at 10:29 PM Reply With Quote
No, headlights I said!!! Why not put them behind an acrylic cover if you realy want that type of light. I just think it destroys the front end look. I admit my idea would make it look a bit GT40ish but nought wrong there. Just my opinion though marra!
killerferret666
posted on 15/11/14 at 11:02 PM Reply With Quote
I don't think it would look right with a clear lense and look less complete due to the lense mountings being on show. It would also need to be moulded as couldn't lie flat as the lenses break the natural curve of the light unit open area if that makes sense as I'd had a play around prior to IVA.
Photo of what's behind;
http://imgur.com/jH8En58
I'm going to make the front look similar to this in terms of headlight design and break up the front a bit, although colour won't be in your face like an orange.
Building DDR GT4
Dusty
posted on 16/11/14 at 01:06 AM Reply With Quote
You might have IVA problem with front position lights. I presume they are in one of the headlights. They must be visible from an angle of 80 degrees to the side of the car. The lights shown do not look compliant. You might have to add an actual front position lamp (sidelights) to get through.
killerferret666
posted on 16/11/14 at 07:38 AM Reply With Quote
I've already passed IVA and got a registration plate. So that all passed ok. The front position lamps are actually the little black dots in the headlîght covers in photos a bit higher up the page. But you are right if I had gone for models with the position lights in the units it would of failed I think as well.
Building DDR GT4
