Author: Subject: EFI and turbo conversion, one at a time, or both at once?
fha772
posted on 4/12/14 at 08:39 PM Reply With Quote
Hi all,
I'm getting well on with my EFI conversion on my Mercedes.
But I've been pondering over the last week, whether to get on with doing the turbo conversion at the same time.
Or get the EFI working first, before I get the turbo on.
What would you guys do?
I can't decide whether I'm just giving myself more headaches by doing both jobs together.
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
r1_pete
posted on 4/12/14 at 09:02 PM Reply With Quote
I'm approaching the e type efi conversion a step at a time:
1. New tuned head, will run with the same inlet / ignition setup as before to check cam timing etc.
2. Convert from Megajolt to Megasquirt ignition, to check crank sensing etc. is all OK, check power feeds, sensors etc.
3. Fit the efi, get it running as well as I can.
4. off to Bailey Performance for proper mapping.
fha772
posted on 4/12/14 at 09:23 PM Reply With Quote
To be honest, I'm 70/30 about which way to go, I'm more inclined to keep going a step at a time. But there's a few bits and pieces that I will have to make for the EFI conversion, then have to alter/remake when I fit the turbo, and that's what is swaying me towards doing both together.
r1_pete
posted on 4/12/14 at 09:30 PM Reply With Quote
Yep, understand, my view is I'd rather know which step introduced a problem. I'm sure there will be some, and chasing false leads could take longer and be more frustrating than the extra time taken to go one step at a time....
Oddified
posted on 4/12/14 at 09:37 PM Reply With Quote
I'm happy doing things in stages. Originally my kitten was built with the na cosworth on carbs and ignition only ecu, then different ecu's and then, nitrous, changed over to tb's/fuel injection, cams, manifolds and now a supercharger. It's a progression and for me part of the fun
Ian
mark chandler
posted on 4/12/14 at 10:17 PM Reply With Quote
I converted to injection, just made the plenum with boosting the engine in mind, single 2" stub with K&N planted on the end, once it was all hunky dory added the turbo 6 months later.
matt_gsxr
posted on 4/12/14 at 11:19 PM Reply With Quote
EFI first and get that sorted
then add the turbo and break it all
http://jpsc.org.uk/forum/
Ivan
posted on 5/12/14 at 09:18 AM Reply With Quote
- What he said
ashg
posted on 5/12/14 at 11:33 AM Reply With Quote
I would just do it all in one hit then you only have to pay out once to get it mapped.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Chris_Xtreme
posted on 5/12/14 at 05:32 PM Reply With Quote
If you were going to just getting running on EFI, be happy ish then turbo it, a two stage could at least prove something on the way. I wouldn't pay out twice on the rolling road, tho.
