Jenko
posted on 6/12/14 at 05:56 PM |
loads of stuff for sale
Following post builds items up for grabs:
Pair LED indicators (not e marked) hardly used- £8
Two brand new wheel bearings fit Puma, Fiesta mk4 etc - £12
2 x VW rear calipers and carriers - need a good clean ( I painted one!) - £23 - SOLD to LIAM
Indicator stalks / light / hazard etc modual - from PUMA / fiesta - £10
28mm temp sender adaptor - fits ford / omex unf senders - £5 - SOLD TO JONI
2x high quality exhaust clamps - 50mm open - £10
Trumpets from GSXR 600 TB's - £15
Manifold adaptors (not sure what they are from)40mm ID - 68mm Hole spacing - £10
Edis module, no idea if it works as I've never used it - £5
£2 / item postage, but welcome to pick up from Southampton / Winchester area
[Edited on 6/12/14 by Jenko]
[Edited on 7/12/14 by Jenko]
MY BLOG - http://westfieldv8.blogspot.co.uk/
joni
posted on 6/12/14 at 07:06 PM |
Temp
Hi buddy I will take the temp sender adapter it says 28 mm is it or as you have on you add 23 ?
liam.mccaffrey
can i have first dibs on the calipers please
Build Blog
Build Photo Album
Jenko
posted on 6/12/14 at 11:45 PM |
Calipers sold to Liam....
19sac65
posted on 7/12/14 at 08:26 AM |
Hi jenko
Can you tell me the id of the trumpets please
snakebelly
posted on 7/12/14 at 09:07 AM |
Any idea what the exhaust clamps will clamp down to please?
Jenko
posted on 7/12/14 at 09:56 AM |
All I can do is direct you to the ebay add which says 2" - They are stainless, good quality, and were £12 each
304 Stainless Steel 2"'inch Exhaust Pipe Connector coupler Heavy duty adapter
Jenko
posted on 7/12/14 at 09:58 AM |
quote: Originally posted by 19sac65
Hi jenko
Id of trumpets is 45mm. They fit over an OD diameter of throttle body of 48mm.
Greenie
posted on 7/12/14 at 01:57 PM |
2nd dibs on the Temp sender.......
samjc
posted on 7/12/14 at 07:02 PM |
What would postage be on the clanps to doncaster as very intrested cheers.
Jenko
posted on 7/12/14 at 07:38 PM |
postage is £2 for everything here.
samjc
posted on 9/12/14 at 04:33 PM |
Can you message me a paypal adress for the clamps please.
