Author: Subject: Close to putting down my deposit..
knobby
posted on 8/12/14 at 09:36 PM Reply With Quote
So about to bite the bullet and put down my deposit on a Vortx, will be going with the CBR1000RR engine as recommended by MNR.
Any last minute recommendations / comments before I move forward?
Knobby..
daniel mason
posted on 8/12/14 at 09:45 PM Reply With Quote
Yes mate. Enjoy the car and the build. The guys up there really are nice people which seems rare in this day and age!
Make sure Chris buys you a beer at the local! I've had several with the mnr guys and Iain b
TimC
posted on 9/12/14 at 09:44 AM Reply With Quote
Knobby..
Have you thought about the chain driven GM3.
adithorp
posted on 9/12/14 at 10:23 AM Reply With Quote
Knobby..
Left hand drive isn't it?
http://jpsc.org.uk/forum/
knobby
posted on 10/12/14 at 10:45 PM Reply With Quote
DEPOSIT PAID!!!!! Bring on Feb!
Can't wait...
Some planning to do now.
knobby
posted on 1/2/15 at 07:06 AM Reply With Quote
I started a build blog if anyone's interested. I couldn't find any other MNR Vortx CBR 1000 RR build diaries so if anyone else is starting out this might be of interest.
http://knobbymnrvortx.blogspot.co.uk
CosKev3
posted on 1/2/15 at 11:33 AM Reply With Quote
Looks good
Will have a proper look later on ipad, too many pics to look at on phone.
Whats the crack with deleting water pump on these, just due to room or something else?
knobby
posted on 1/2/15 at 11:56 AM Reply With Quote
Thanks.
Remove the water pump to run an electric pump. If you leave the mechanical pump in place there's no coolant in it to cool it down thus why you remove and add the delete kit.
Building a CBR1000RR MNR Vortx - http://knobbymnrvortx.blogspot.co.uk
CosKev3
posted on 1/2/15 at 12:14 PM Reply With Quote
Thanks.
so the electric pump is just out of choice, not a necessity with this engine/instalation in a car?
knobby
posted on 1/2/15 at 10:47 PM Reply With Quote
Well here's what I've been told...
Oil cooler is a must. If you intend on tracking the car and pushing it hard on track the oil temps shoot through the roof making an oil cooler is a must from day one. Apparently the electric water pump isn't essential but again if you push hard on track, come in to the pits and turn the engine off to reduce the heat the water temps can continue to rise. With an electric pump you can turn the engine off turn the ignition back on and run the electric pump to bring the temps down.
posted on 2/2/15 at 01:45 PM Reply With Quote
Nice build thread there.
Can you not wire the water pump up so it will run until the temp drops right down? Like using a fan switch like you would with the rad fan?
knobby
posted on 2/2/15 at 02:49 PM Reply With Quote
Yes. But apparently the controller pulls silly high amps and causes miss fires so easier to run flat out.
Did you like my 6 hours with the wiring loom?
