Scuzzle
| posted on 13/12/14 at 06:17 PM |
Fixings for Carbon Fibre Panel
What's the best way to get a threaded rod through a carbon fibre panel. I have a carbon fibre spoiler I need to fit which is meant to be bonded
or taped on but I think I would prefer to bolt it on as I lifted some paint last time I removed it and I'd rather not risk making it any worse
in future, fortunately it's hidden when fitted back on.
So far I have 2x options that spring to my mind.
1. drill a hole and fit rivnuts and insert threaded studs into these with some loctite to make studs but I am worried that the CF will just rip apart
when I tighten them up.
2. drill a hole in the bottom of the spoiler and drill a bigger hole beside it to allow me to get my fingers inside it to fit a large washer and bolt
through from inside it.
Does anyone have any ideas or suggestions?
daniel mason
| posted on 13/12/14 at 06:43 PM |
What does the spoiler mount to? Frame or bodywork? Mine has special mounting brackets which are a nice touch! Pm your number and I'll text you
the picture
Scuzzle
posted on 13/12/14 at 06:50 PM |
It mounts to the body work, PM'd you
| posted on 14/12/14 at 01:26 PM |
Big heads?
