Author: Subject: Range Rover diesel cold starting
ChrisW
posted on 29/12/14 at 10:43 PM Reply With Quote
Hi everyone
We have a 55 plate Range Rover Sport 2.7 TDV6 that the Mrs drives. It's been spot on up to now, but in the cold on the last couple of mornings it's not wanted to start. I've not much experience with diesel engines so looking for some advice please!
It's happy to start once it's warmed up a bit (as in, left in the sun for a few hours), and once the engine has run for a bit it starts up perfectly. The battery was only changed last year so it's got plenty of cranking power in it. When it's cranking there is plenty of white smoke from the exhaust which I assume is atomised diesel passing through the cylinders and out the exhaust therefore I guess the fuel system is working ie it's not air in the fuel lines or anything.
I guess the likely culprit is knackered glow plugs, however the manual says that if the car detects a glow plug problem the light will stay on after the engine starts which it doesn't. Also a bit of reading online suggests that they like to seize in the head on these engines so I'm looking at that job with a high level of fear!
So, for the sake of keeping mobile, what is the recommended technique for starting a diesel engine from cold when the glow plugs are dodgy? I read that it's not possible to 'flood' a diesel engine like you can a diesel so is it best just to keep cranking and hope it eventually fires?
Can glow plugs be 'tested' by looking at their resistance?
If a knackered one snaps in the head, am I any worse off than I am now? By that I mean if a plug is not working now am I in any worse situation if I try to get it out and it snaps? I read somewhere that the engine will start without all plugs working but will be a bit lumpy for the first 30 seconds or so. For the sake of keeping the thing running I would be happy with that.
(Note that we're probably going to trade it in come the Spring anyway so this just needs to be a temporary fix!)
Cheers, Chris
My gaff my rules
mark chandler
posted on 29/12/14 at 10:52 PM Reply With Quote
Measuring the glow plug resistance is a good start, just look for one that is very different to the rest.
Before then try keying the ignition for 5 seconds before cranking it over to get the plugs hot, in the old days you waited from the glow plug light to extinguish before cranking.
ChrisW
posted on 29/12/14 at 10:58 PM Reply With Quote
Thanks.
Yes, I wait for the light to go out before cranking. In this weather it takes 5-6 seconds. A tip I read was to fire the plugs 3-4 times before cranking. Not sure if that helped or not but I eventually got it started this morning once the sun had warmed it up a little.
Chris
My gaff my rules
Wadders
posted on 29/12/14 at 11:03 PM Reply With Quote
On our old jeep I find turning the ignition key twice before attempting to start the motor helps.....bit of a faff but starts clean every time.
Essentially the glow plugs are heating up twice.....no idea if that would help on a modern diesel......the jeep engine would be at home in a tractor
Slimy38
posted on 29/12/14 at 11:05 PM Reply With Quote
I've been told the quality of diesel can play a part when it's cold, although I'm not sure what truth there is in that. I know that I've had petrol cars struggle with crap fuel, I would expect the same could apply with diesel?
ianhurley20
posted on 29/12/14 at 11:43 PM Reply With Quote
Glow plugs get HOT! With the aid of a bit of bottle and quickreactions you can put a finger on each glow plug and if it get hot then - a move finger and b test the next one. Not tried it on a TDV6 but have on many other diesels and the one or two that stay cold are usually the culprits. That said I bottled it on a friends diesel as I could only get one of the four failed glow plugs out of the aluminum head but afterwards it did start but sounded very lumpy for a while
ChrisW
posted on 29/12/14 at 11:50 PM Reply With Quote
I assume you mean take them out of the head first? To be honest, for the sake of £15 each, if I could get them out I would replace them.
However, I do have one of those laser thermometers (have you seen how cheap they are from China these days?). I wonder if I could diagnose which ones are knackered in situ if I get the Mrs to turn the ignition on whilst I look at the temperatures? Or do you think the head would soak all the heat away?
Chris
My gaff my rules
tul214
posted on 29/12/14 at 11:56 PM Reply With Quote
Almost certainly will be the glow plugs. They can be difficult to remove but there are a few tricks that are being discussed on the Disco3 forum.
You could also invest in a remote unit for your FBH to warm things up before you need to start it.
[Edited on 29/12/14 by tul214]
1.6 Raw Super6 sold
froggy
posted on 29/12/14 at 11:57 PM Reply With Quote
They have very long thin glow plugs and snap very easily as a 3" smooth section sits in the head and the top part just isn't long enough to unstick them if they are tight . There is a pneumatic tool to help wind them out like a reverse impact driver but the thin plugs are a pain in lots of diesels , done one tdv6 and snapped 5 out of six despite doing everything possible to get them moving . Ended up taking the body off to pull the heads off and drill them out on a mill to keep the angle and not burst through .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
ChrisW
posted on 30/12/14 at 12:52 AM Reply With Quote
Thanks guys
That Laser 'broken glow plug removal kit' looks like a reasonable precaution if I was to attempt to DIY the plugs. Has anyone had any experience of using it?
What happens if/when they snap? Is the cylinder still sealed? Could I just leave them disconnected? After all, for the ones that are already knackered, they are not going to work any less!
Will they come out with regular 'long reach' sockets or do I need a special glow plug one?
What is the best starting technique in the mean time? Do I just crank the thing until it eventually fires? Or am I just asking for a knackered starter by doing that?
Chris
My gaff my rules
ian locostzx9rc2
posted on 30/12/14 at 08:20 AM Reply With Quote
Turn ign on for 10 seconds turn off for 10 seconds turn on for 10 seconds then crank if it fires up with less cranking its Defoe a glow plug issue lets the glow plugs have a longer heat heat cycle .
ianhurley20
posted on 30/12/14 at 08:51 AM Reply With Quote
Chris
No - you leave them in the head - this is a way of deciding which ones to risk trying to remove
ianhurley20
posted on 30/12/14 at 08:52 AM Reply With Quote
the Laser thing sounds an improvement on my touch with a finger idea
Benzine
posted on 30/12/14 at 10:16 AM Reply With Quote
My dad's disco, with the same V6 diesel, started having starting issues a couple of winters ago. It was the glow plugs (no warning lights came up). A whiff of ether and it started like a champ each morning. He then went ahead with glow plug replacement and half of them were seized and sheared, big bill to sort that out. I'd have just kept using cold start until the weather got warmer.
froggy
posted on 30/12/14 at 10:30 AM Reply With Quote
The laser tool is ok but you can't accurately keep it level and the tap to grab hold of the lower section is virtually the same size as the diameter of the hole so a fraction out and your into the head . It's quicker to remove the body to get the cylinder heads off and get them out with the head and drill fixed in position. Ended up being a 2k bill for £60 worth of glow plugs
ChrisW
posted on 30/12/14 at 11:21 AM Reply With Quote
Do you mean that Easy Start aerosol stuff? Didn't realise that would work on a diesel! Where did you spray it? Obviously in the intake, but I guess the filter will soak it up so perhaps you have to disconnect the airbox each time?
Thanks for the info on the laser tool, Froggy. Perhaps not the simple fix that it looks like in the video. Annoying that we've only just spent £1k having the rear cambelt done. If I'd known the body was likely to have to come off anyway I wouldn't have spent money getting a specialist to do the belt with the body in situ!
Chris
My gaff my rules
Wheels244
posted on 30/12/14 at 11:48 AM Reply With Quote
Hi Chris
You've got me worried now - I've got the same engine in my Discovery 3 - all fine at the moment, hope it stays that way.
Done a quick search of the Disco 3 forum for you. Quite a few people have had success with this problem by fitting a remote start for the FBH from Bell Autoservices - it warms the coolant up for about half an hour before driving, with the added advantage it heats the car up quicker, helps with defrosting etc. might be worth a look.
I've read horror stories of body off, heads off, to remove the broken heater plugs with bills £2k+ !
Might worth a try with the FBH ?
Rob
[Edited on 30/12/14 by Wheels244]
Build Blog: http://wheels244.wordpress.com/
Benzine
posted on 30/12/14 at 11:52 AM Reply With Quote
Yep Easy Start/Cold Start/Start Ya' Bastard etc. I didn't have to disconnect anything with the discovery, there was enough of a panel gap to squirt it in the right direction (air intake was inside the drivers side wing, don't know about range rover)
[Edited on 30-12-2014 by Benzine]
Wheels244
posted on 30/12/14 at 11:55 AM Reply With Quote
Link for you - showing out of stock at the moment - might be worth a phone call.
https://secure.bellautoservices.co.uk/store/webasto-fbh-controller-rf-plip-activated/
Easy Start - can raise the dead :-)
froggy
posted on 30/12/14 at 01:20 PM Reply With Quote
The first one I did was my partners wife's car and no one would bite the bullet with the ratchet to get them out . They all moved but tightened up and snapped despite trying every trick to keep them moving . Above freezing point a common rail should get going without heat with a couple of coughs to clear out any unburnt fuel . The next one I did we managed to get three out and changed them . Hasn't been in touch over the last few days so I assume three is enough to get it going
Wheels244
posted on 30/12/14 at 01:31 PM Reply With Quote
Did you get the broken ones out Froggy ?
Rob
tul214
posted on 30/12/14 at 07:05 PM Reply With Quote
Surely you mean the front cam belt? The rear belt only drives the fuel pump and doesn't have to be done as religiously as the main cam belt - even so it should have only been £600 ish .
1.6 Raw Super6 sold
posted on 31/12/14 at 06:38 PM Reply With Quote
Ouch. Sounds like"£££££££
Is there less chance of them snapping when hot or cold?
Seems like a poor design, as a ptecaution, mebbe worth removing plugs each year but who can be bothered with that.
DW100
posted on 2/1/15 at 11:30 PM Reply With Quote
Definitely worth doing a resistance test on them before trying to remove from head. A good one should be around 7 to 10 ohms between centre glow plug connection and cylinder head.
threadbare wallet
posted on 3/1/15 at 07:07 AM Reply With Quote
Stick easy start in the in take just before cracking.never disturb anything on that engine.....
Very few things are "really" needed.
