ali2992
posted on 4/2/15 at 04:04 PM |
Smiths Telemetrix Gauges
Selling a set of Smiths Telemetrix gauges. They are used and show signs of use with a few scratches on the bezels. The fuel gauge has part of the
retaining clip mechanism broken and subsequently repaired (Pictured), and the oil pressure gauge is missing the bracket but its trivial to make a
spare bracket, I did and it worked fine. The water gauge also has a small crack on the outer casing which has been glued. (Pictured) The faces of all
the gauges look great and when installed in the dash look as new!
NO SENDERS WILL BE INCLUDED. You'll need a telemetrix compatible fuel sender, a mechanical oil pressure sender, magnetic pickup speed sensor and
water temp sender.
£200 + postage
Pictures at link below
http://s1361.photobucket.com/user/ali2992/library/Gauges
ali2992
posted on 26/2/15 at 11:36 AM |
Still here, £150 + postage
ali2992
posted on 26/2/15 at 05:51 PM |
SOLD
