simonrh
posted on 7/2/15 at 10:15 PM |
Suggestions for tyres
Accidentally just bought a set of used superleggera for my quantum off ebay.
Standard tyre size is 195/50 r15.
Rims are 7" wide and so could carry 195/50 or 205/45.
Are the 195s going to be a better bet on a (fairly heavy compared to others) seven sequence car as they have a taller side wall for comfort and to
flex and heat up. Or would you go for the fat wheels for glamour!
What are a good road tyre that comes in pretty cheap but grippy. Mileage probably isn't an issue.
[Edited on 8/2/15 by simonrh]
OliilO
posted on 7/2/15 at 10:18 PM |
I'd go R1R for a mix of track and road. Similar (or same?) compound to R888 but with a better pattern for wet weather and about half the price.
I'd have thought that 195s would be sufficient unless you're running big power.
simonrh
posted on 7/2/15 at 10:20 PM |
It may occasionally get shown a slow track day but it will be 95% Road I should think
Ben_Copeland
posted on 8/2/15 at 06:55 AM |
Second vote for R1R's
I'm running 195/50/15s. 205s are ok if you'll only ever drive it when the road is bone dry otherwise keep to 195s
Openeo website seems cheapest for tyres
[Edited on 8/2/15 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
matt5964
posted on 8/2/15 at 08:30 AM |
Third vote for the R1Rs whilst you can still get the as they are being discontinued 😳
I run 195 at front and 205 at rear on 6.5j rims
Other option would be Yokohama AD008, that's what I'm going to try next if the R1Rs are all gone by then.
If your in Buckden cambs the apex tyres Peterborough where the cheapest buy a long way when I got mine (cheaper than the Internet supply only and
there price was fitted with some nice Porsche style valves)
[Edited on 8/2/15 by matt5964]
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
simonrh
posted on 10/2/15 at 08:43 PM |
Got a set of r1r coming, 195 wide all round (pinto is never going to trouble them!)
Wheels arrived today and, aside from a couple of chips, look gorgeous.
posted on 11/2/15 at 12:00 AM |
Any pics??
simonrh
posted on 11/2/15 at 07:14 AM |
Will do pics when it is all together. The big reveal like on telly!
simonrh
posted on 12/2/15 at 10:17 PM |
Preview as I now have tyres fitted and not sure when i am going to be able to fit wheels to car.
R1R 195/50 R15 V rated on 15x7 Superleggeras.
They weight 14.3kg per corner according to our bathroom scales which i think is OK?
Chris_Xtreme
posted on 13/2/15 at 12:33 PM |
You've got to take it for a spin on the new rubber My Xtreme is getting quite low on the tread and when it is back on the road I am going to
need to get some new tyres too!
simonrh
posted on 13/2/15 at 01:38 PM |
First job this weekend is to get Nodiz timed in. New plug leads arrived today.
Crank sensor was hooked up last night so should be about there.
Chris_Xtreme
posted on 13/2/15 at 01:49 PM |
nice, just looked up nodiz, like it. you'll be able to sort any timing curve problems out, might help the running hot issue, if it was still
there.
simonrh
posted on 13/2/15 at 02:01 PM |
Polo rad has made running hot a thing of the past. Nodiz was on special at Xmas and I was after something like that anyway because of timing wander
etc. (and the glamour!)
Chris_Xtreme
posted on 13/2/15 at 02:04 PM |
I went for 8 individual coil packs on mine, for that reason - cause I can and to be a bit fancy!
simonrh
posted on 15/2/15 at 01:39 PM |
BEFORE:
AFTER:
[Edited on 15/2/15 by simonrh]
Chris_Xtreme
posted on 15/2/15 at 03:00 PM |
Nice, they do suit it much better
b14wrc
posted on 19/2/15 at 12:19 PM |
Yes, they look sweet!
20vt powered rear engined locost
Ben_Copeland
posted on 19/2/15 at 12:22 PM |
Much better !
Ben
Roadster
simonrh
posted on 19/2/15 at 01:16 PM |
Don't bloody fit properly t the rear sill though!
Ben_Copeland
posted on 19/2/15 at 01:26 PM |
Why whats the issue?
Ben
Roadster
simonrh
posted on 19/2/15 at 02:15 PM |
They sit on the rims a little wider than previous and can just rub the wheel arch edge beading over bumps.
The rims are actually offset 2mm more than the previous ones (ET37 was ET35). So if anything should be more clearance than before
Tyres same width but they do have a rim protectcing feature
My rear arches have a plastic bead / trim round them that I am going to have a look at removing to start with as it is just that that is rubbing.
If that fixes it then i might reprofile the arch slightly to make it permanent (or just leave the beading off).
Also at full droop (in the air on a jack) the front right wheel clears the suspension but the wheel weights just touch the A arms. Must be a little
more suspension travel on right than left as it is OK on the other side. I have decided to run 3mm spacers for now to ensure clearance until I can
sort it out for definite.
Ben_Copeland
posted on 19/2/15 at 02:23 PM |
Cars unlikely to see full droop tho ?
Can you raise the rear suspension slightly? or just trim a bit off the arch.
I had something similar where my tyres balloon at full throttle and made a groove in my tyre lol I just raised the back slightly to counter act the
squat and balloon effect
Ben
Roadster
simonrh
posted on 19/2/15 at 02:26 PM |
Think the stock shocks are quite basic. Maybe I can shim the spring seats higher
AlexXtreme
posted on 23/8/15 at 06:06 PM |
Hi Simon,
As a fellow xtreme owner I would be keen to hear what you thought of these tyres as I need to replace a couple of my tyres?
Have you tried them in the wet? (not that I get the car wet very often).
I have similar clearance with the tyres on the back of my car and have slightly damaged the edge :-(.
PS I have just upgrade my rear shocks and it made a big difference from procomp so I can also adjust the height
Alex
Chris_Xtreme
posted on 28/8/15 at 11:29 AM |
I've put R1Rs on my v8 Xtreme and am liking them.
I've done the SKCC euro trip and them some with them. 2000+miles
In the wet they are actually pretty damn good. I was out in the lashing rain yesterday, so the road was properly soaked, floored it at 3000rpm in 2nd
and the wheels didn't spin, I was in a 30zone so the test didn't last very long mind.
Hit a puddle and it is a different story, you definiatly aqua plane more. The ones I had before I think were Avon A520s which didn't aqua plane
any where near as much.
I'd recommend them, whilst you can still get them.
