Author: Subject: Saab 9.3 1.9 tid fuel pump issue
ASH3
posted on 25/3/15 at 06:26 AM Reply With Quote
Hi guys I have a non start issue, fuel pump in the tank will not run it has 10.6volts at the
multiplug and an earth but wont run if I back pin the plug and put 12v to it the pump will run. Also scanner
showed crankshaft position sensor was down new one fitted it ran for a mile towed it home
only to find this no fuel pressure issue scanner says fuel pressure sensor but till I can sort
the tank pump out im lost...any ideas chaps
[Edited on 25/3/15 by ASH3]
Ben_Copeland
posted on 25/3/15 at 06:41 AM Reply With Quote
Id be checking the fuel pump relay. Maybe swap that first. Then check the feed for the relay, just trace it all back.
The pressure fault is probably because the pump isn't running and it's not seeing fuel pressure as it expects.
[Edited on 25/3/15 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
ASH3
posted on 25/3/15 at 07:57 AM Reply With Quote
Ive swopped the relay but still only get 10.8volt at the pump surely it should run without me
Putting 12v to it...
