beaver34
| posted on 1/4/15 at 10:53 AM |
wide track front end
hi,
i fancy making a wide track wishbone setup for my car, my question is would i need longer shocks ie should i move the pickup point further along the
arm or leave it where it is and just make the arms longer with the same geo?
thanks!
tegwin
| posted on 1/4/15 at 11:54 AM |
If you move the shock attachment point inboard on the A arm you increase the bending forces dramatically. Not a brilliant idea on a thin arm...
I'd guess the "correct" way of doing things would require the top shock mount to be moved outboard slightly so that the shock angle
is correct.... Shouldnt need different shocks though
www.verticalhorizonsmedia.tv
beaver34
| posted on 1/4/15 at 01:00 PM |
i would move it outwards if making the wishbone longer, or leave in the same place if moving it outward i would need longer shocks.
i guess my question should have been does running say a inch or 2 inch longer shock help things or not
daveb666
| posted on 1/4/15 at 01:09 PM |
how wide are you planning? My front wishbones are 'as wide' as my rear axle, so around 1" wider on each side I believe.
fesycresy
| posted on 1/4/15 at 01:25 PM |
I totally agree, spend some time speaking to Matt @ Procomp and he suggests a beam to fix the top shock mount.
beaver34
| posted on 1/4/15 at 01:33 PM |
match the rear end really an inch would be fine it think without measuring
daveb666
| posted on 1/4/15 at 01:42 PM |
In that case happy to take any meaurementsif you need any?
motorcycle_mayhem
| posted on 1/4/15 at 02:06 PM |
Westfield's widetrack moves the wishbone's shock pickup a commensurate amount. You then have a longer shock requirement. When I fitted
said wishbones to my Westfield, I was quite surprised at the shallow angle of the shock. Mind you the rears are at quite a silly angle too.
I've seen other wide wishbones with the shock mount in the narrow track location, but with some heavy reinforcement to (presumably) obviate the
bending. You retain the standard shock and angle.
If I was doing this all again, hindsight would tell me to move the chassis top shock mount outboard. Hindsight is good, and accurate too.
| posted on 1/4/15 at 03:17 PM |
The spring rate would also need to go up in this case to keep the same wheel rate.
beaver34
| posted on 1/4/15 at 03:43 PM |
yes might be usefull or ill pop round or meet up somewhere if your out and about
