New Topic New Reply
Author: Subject: Type 9 box + Zetec measurement needed!
PSpirine
posted on 4/4/15 at 10:02 PM Reply With Quote
All,
I'm about to fix some bits on my chassis, and make sure that the engine mount plates are in the correct place (chassis had a Pinto in it previously and I'm cutting the mounts out as I'll be putting in a Zetec).
Can someone tell me what the distance in X axis (along centre line of vehicle) from the Type 9 gearbox mounting to the zetec engine mounts is (to the hole that goes into the chassis plates that accept the rubber mount)
Apologies if vague, I can probably post up a drawing if it'll help!
DIY Si
posted on 5/4/15 at 12:28 PM Reply With Quote
I doubt you'll get an exact answer unless you're using an off the shelf mount. If you're making them yourself, you can put them where fits best for your chosen design.
Sun Tzu, The Art of War
New Topic New Reply
