123standish
posted on 12/4/15 at 01:07 PM |
Changing a Bec engine
Hello,
I am thinking about buying a bec either a Westfield or mk I think. My question is if I bought a Westfield megabusa, how easy would it be to put an r1
in or visa versa, is it purely the engine mounts, changing gear box and associated electrics?
Thanks in advance.
John
CosKev3
posted on 12/4/15 at 01:22 PM |
Your buying one with a knackered engine?
Engine and gearbox are combined on a bike engine.
Are you any good with a welder?
Easiest route would prob be to buy a ready made cradle for the engine, then weld mounts for the new cradle onto your chassis,and then cut off your
lower mounts and reweld on ones to match the R1 lower mounts.
Other things to consider will be propshaft length and exhaust mods, including hole in side panel for exhaust manifold.
[Edited on 12/4/15 by CosKev3]
posted on 12/4/15 at 01:24 PM |
Engine mounts, prop and adapter, wiring, possibly fueling, exhaust, and possibly the bodywork if it's much different in size. Not the end of the
world, but not necessarily a small job.
fesycresy
posted on 12/4/15 at 01:42 PM |
I would advise against it with the Megabusa. Values do drop if you don't have a Busa motor in a Megabusa chassis. Likewise megablade / megabird.
Why not just put another Busa motor in?
With the MK it wouldn't hit values too much because MK support all bike engines and I think prospective owners would look at the engineering
quality of the swap rather than 'Westfield supported' as with the Megas.
123standish
posted on 12/4/15 at 01:58 PM |
Very helpful.
No we are looking for one complete and ready to go, but various post on here suggest they don't last forever and thinking about worst case
situation. Regarding going from a busa to an R1 purely on the cost of a new engine.
I am not a regular welder so would be a trip on the trailer to a local garage.
CosKev3
posted on 12/4/15 at 02:14 PM |
It wouldn't be cheap paying someone to do it, probably heading towards the price of a replacement busa engine I would guess by the time
you've bought a R1 engine/wiring/prop/exhaust modding and fitting costs.
ReMan
posted on 12/4/15 at 08:54 PM |
If properly prepped, dry sump or similar at least and working well there's no reason to e be thinking of it going pop in a hurry.
But in a any case it would be a bit backward to downgrade and as mentioned probably similar cost. A buss engined car will attract a bit of a premium
one R1/Blade IMHO so I'd keep it that way
www.plusnine.co.uk
