Author: Subject: Problem with electricity meter
James
posted on 14/4/15 at 02:15 PM Reply With Quote
Without wanting to go into too many details on a public forum....
I noticed on a friend's electricity meter one of the output tails has got VERY hot and melted the front cover of the meter and burnt the contacts and melted the plastic around it.
My friend re-wired the house 12mths ago and had the re-wiring checked and signed off by another friend who's Part P.
Should my friend phone the electricity company for a replacement meter? Or can he buy them himself? Can you program it with the accurate number (seems unlikely!).
Is anyone going to get in trouble over this?
James
[Edited on 14/4/15 by James]
Slimy38
posted on 14/4/15 at 02:23 PM Reply With Quote
Aren't the meters owned by the electric company? They're all lock wired and tagged to ensure that they cannot be altered or replaced.
Perhaps it's an opportunity to have a smart meter installed?
whitestu
posted on 14/4/15 at 02:27 PM Reply With Quote
The meter belongs to the supply company so they need to be called. Did he touch the meter during the rewire? There should be no need to as the meter tails normally go to a fuse before connecting to the consumer unit.
Stu
posted on 14/4/15 at 03:19 PM Reply With Quote
What the electrical supplier will do is take the old meter off, note the current reading, then put the new one on and take that meter's reading. The system will then continue to count your units used, hopefully correctly.
Sporty
posted on 14/4/15 at 03:38 PM Reply With Quote
Sounds like the connection has deteriorated become high resistance and created heat. Just report it to the supply company and they will come and replace it free of charge, it needs to be reported as it is a fire risk and they will come out immediately.
I used to work for one of the distribution companies and it isn't an unusual issue.
Nobody will get into trouble as long as the meter hasn't been tampered with, if the tags are missing its also not unusual as they often get cut off and not replaced during fault repairs and testing.
cliftyhanger
posted on 14/4/15 at 03:41 PM Reply With Quote
I my experience, the crew will arrive, tut tut and change the meter. Worth taking a pic when they arrive showing all the meter details, including serial numbers etc as well as readings.
I doubt anybody will ask for any paperwork. Play dumb, the "I have no idea about electrics" look. Make them tea, give them a biscuit. Job done. Any comeback, wave the paperwork at them, but I can't see that happening.
jacko
posted on 14/4/15 at 03:51 PM Reply With Quote
the heat caused by the electric makes the wire tale expand and contract making a bad connection / over heat
get the electric company suppler in fast
my Son does this job for a living
Jacko
Brook_lands
posted on 14/4/15 at 04:04 PM Reply With Quote
Not quite the same but managed to blow the 60amp main house fuse the other day. Called the electricity company because its in their part of the system. Engineer turn up, no comments or anything, changed the fuse and then turn out to be a total petrol head and stayed until his next call came in drinking coffee and talking old cars.
I'm sure they have seen it all before but if the meter hasn't been tampered with they just get on with it.
motorcycle_mayhem
posted on 14/4/15 at 07:49 PM Reply With Quote
Just had the original meter replaced with a new one, last week. Guy came in, pulled the fuse, changed the meter and ran away - after checking he'd got the polarity the right way around. Original meter was a mechanical E7 driven one, with a very unreliable E7 timing. Now replaced with a more reliable pre-programmed thing, not a smart meter because there's no reliable signal here apparently. Plenty of people had been around previously to uprate the supply (60 to 100A), shut it all down to cut the trees, reset the mechanical bit frequently and sort out the PME. All contractors/subcontractors of either the supply or metering companies, all not bothered (or aware) of the state that the previous visitors had left the thing in... hey ho.
Anyway..
The meter belongs to the electricity company, the supply to it by someone else. It sounds as though you've seen a resistive supply, that will need to be looked at swiftly, with a new meter requirement. None of this will cause any issues, unless there's a spliced supply to the cannabis farm in the loft and that's the cause....
DIY Si
posted on 14/4/15 at 08:14 PM Reply With Quote
What everyone has said so far is right, the only people able to put this right are the electric company. Get onto them sharpish, as the meters can go up in flames with enough load passing through them in such a state. Do NOT replace it with a meter brought from Ebay, AN Other electrical outlet etc as to do so counts as theft of electricity, and is viewed very dimly by all of the suppliers.
As someone who does this for a living, the guy that turns up won't really care about the damage, although the regs around checking damaged equipment are getting stricter. For the company I work for, that rhymes with peon, if I arrived I would need to fill in a couple of forms, take a few photos and then basically put it right. But that is only because I'm the area's lead engineer. No-one else would give a monkeys to be fair, and the chances of me doing the paperwork would be slim if enough biscuits appear!!
If the guy that turns up can be persuaded, I would ask about fitting an isolator switch whilst he's got the power off. That will give your mate a certified point at which he can power down and work safely on the rest of the system, rather than having to remove the seals like he did last time!
Sun Tzu, The Art of War
What he said. It happens. Call the supply company, they fix, they don't give a sh1t unless they catch you steeling electrons.
Tails do come lose during a rewire.
Dusty
posted on 14/4/15 at 09:13 PM Reply With Quote
Had this a couple of years ago. Walking through the hallway I smelt that electric hot/burning smell coming from the meter cupboard. Rang the electric people and they came the same day as it was a safety issue. Didn't cost a penny and the electrician who came didn't seem in the least surprised by the fault, only in the fire risk.
spiderman
posted on 14/4/15 at 10:00 PM Reply With Quote
If your mates mate is only part p registered he can't sign off a total rewire it has to be someone with C&G 2391 or what ever has superseded it since I was last doing electrical sub contracting
Spider
James
posted on 14/4/15 at 11:57 PM Reply With Quote
Okay, thanks for all the advice everyone!
So, after a couple of phone calls and a wait a guy turned up. Offered tea and biscuits several times he changed the meter with no queries.
Frustratingly, the post above yours was the last one I read before he came. He removed the 'junction' box (i cant remember the proper name but a big square, brown jobby) that was between the meter and the consumer unit and connected them direct whilst I was doing something else. When I mentioned the further building works to be done he said: "oh, you should've said, I'd have fitted an isolator switch". Grrrr!
Oh well, all sorted now at least!
Thanks for your help everyone!!!
James
slingshot2000
posted on 15/4/15 at 06:30 AM Reply With Quote
IF during the re-wire, your friend had fitted a consumer unit that complies with the "17th Edition of the electrical regulations" you will NOT require a separate isolator in-between the meter and you consumer unit. Your consumer unit should contain a 100amp switch that will isolate all circuits and 2 RCDs, that will isolate some circuits and allow you to still have some operating.
Also, if the consumer unit was installed after the first of January this year, it will be of all metal construction.
Don't get me started on other people signing off work they have not done, it is not allowed under ANY circumstances, and for good reason !
DIY Si
posted on 15/4/15 at 07:35 AM Reply With Quote
An isolator may not be required, but having one sure comes in handy! We used to have guys who spent all day just fitting them for the local councils.
slingshot2000
posted on 15/4/15 at 07:36 PM Reply With Quote
A new consumer unit to the 17th Edition of the Regs, will have an isolator built in. There will be no need for another, unless something dodgy is going on !
DIY Si
posted on 15/4/15 at 09:33 PM Reply With Quote
But how do you go about fitting said board, legally, without an isolator? Or upgrading it in the future?
posted on 15/4/15 at 09:56 PM Reply With Quote
Working live isn't verbotten is it? Hope not
My understanding is the supply companies prefer people to accidentally pull out the 100A fuse than work live but it's not exactly complicated.... you just don't lick the massive thick scary cables.
SteveWalker
posted on 15/4/15 at 10:19 PM Reply With Quote
That's what I did some years ago. It's also what the "pros" did a couple of months later - the meter reader noticed the new consumer unit and arranged for the main fuse to be uprated from 60A to 100A, which involved a new fuseholder; they arrived without warning (luckily I'd taken a day off), put rubber gloves on, smashed the old fuseholder apart with a big hammer, fitted and connected the new one and then filled the cable entries with an epoxy putty. New fuse in the holder, seal on and done.
DIY Si
posted on 15/4/15 at 10:32 PM Reply With Quote
Sounds about right for some of the mains crews I know! But they do tend to use a plastic handled hammer these days!
