<<  1    2    3    4  >>
Author: Subject: Possible LED headlight group buy
russbost
posted on 26/4/15 at 07:11 AM Reply With Quote
Originally posted by FuryRebuild
Hi Russ
In that case, put me down for a pair of the 7" monsters.
Many thanks
Mark
Mark, looking at the above post, it looks as tho' I'm wrong about the Fury having 7" lights, it would appear they are 5 & 3/4! Might be best to run a tape over them check!
russbost
posted on 26/4/15 at 07:18 AM Reply With Quote
Originally posted by HowardB
Mark.
I have measured the hole the bowl fits through... approx 4 3/4" and the front fixing ring is approx 6". I don't think that there is space for the 7" lamps under the covers, so I conclude that it takes the smaller 5 3/4" fitment.
Russ,
How soon do I need to commit to a purchase?
[Edited on 25/4/15 by HowardB]
My apologies, thought they were 7" on the Fury, there have only been 2 common lamp sizes in the UK (excluding Dominators & twin headlamp setups) before we went to modern lamps tailored to each vehicle; which are 5 & 3/4" & 7", so if it's bigger than 4" (Dominator size) & smaller than 7" it has to be the 5 & 3/4"
Re committing to purchase, it's still a case of seeing how many are interested, tho' from what we have here & elsewhere it will almost certainly be going ahead. I'm away for 2 weeks from Mon 27th (webshop, brake hose making etc. will all run as normal, I now have someone working for me full time) & we'll sort out confirmed orders & deposits then so week starting 11th May, will need a firm committment deposit during that week I would think
FuryRebuild
posted on 26/4/15 at 09:03 AM Reply With Quote
HowardB, Russ
Many thanks for the advice so far. I am still committed to the brightest lights I can get in there for the aperture size.
Mark
www.furyrebuild.co.uk
John G
posted on 26/4/15 at 01:20 PM Reply With Quote
LED lights
I am interested in a 5 3/4 set please.
Regards, John
james h
posted on 26/4/15 at 05:29 PM Reply With Quote
Are the 5 3/4" ones 95mm deep? Or is that for the 7" lights?
karlak
posted on 26/4/15 at 05:40 PM Reply With Quote
I will measure up what lights I have on mine, but I do like the 5 3/4 option with the LED/DRL halo.
Having said that I was going to replace my current chrome lights with some smaller 4 inch black ones I purchased a while back. Am I right in thinking these 4 inch lights would be next to useless, other than looking nice and sleek ?
If I were to keep my Chrome ones and get the LED inserts, what options would I have for turning the chrome to black, painting them etc ?
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
adithorp
posted on 26/4/15 at 05:44 PM Reply With Quote
I'm interested in a pair of 5 3/4" ones.
The Fury LeMans bonnet definitely takes 5 3/4" lamps. The Classic bonnet (I believe) takes 7" units.
http://jpsc.org.uk/forum/
HowardB
posted on 26/4/15 at 05:45 PM Reply With Quote
I'll join the list for some 5 3/4" units then. Extra bright please
Howard
HowardB
posted on 26/4/15 at 09:13 PM Reply With Quote
Howard
stevebubs
posted on 26/4/15 at 11:09 PM Reply With Quote
Classic definitely takes 7"
HowardB
posted on 27/4/15 at 08:02 PM Reply With Quote
this is what the fury le-mans bonnet fitting looks like,. and the markings from the lens,... I will remove the headlight cover and measure properly at the weekend
lens
lens
headlight_back
headlight_back
headlight_front
headlight_front
either that will help or it will confuse,.... LOL
Howard
FuryRebuild
posted on 27/4/15 at 10:13 PM Reply With Quote
Looking at that, there is no way a 7" goes in there.
lens
lens
headlight_back
headlight_back
headlight_front
headlight_front
adithorp
posted on 27/4/15 at 11:03 PM Reply With Quote
That'd be because it's a LeMans bonnet and they take 5 3/4" lamps.
HowardB
posted on 28/4/15 at 05:57 AM Reply With Quote
Adi,
I agree, that's what I thought and that is why I took the pictures. The confusion was because the lamps are marked as a 7R-01066
thanks for confirming my conclusions,.
see you at Stonleigh?
Howard
gkfury
posted on 3/5/15 at 05:20 PM Reply With Quote
I'm interested in a pair of 5 3/4.
inkafone
posted on 5/5/15 at 01:08 PM Reply With Quote
Put me down for 5.75 please
peter030371
posted on 8/5/15 at 09:26 AM Reply With Quote
Can you not get these for the Dominator? Not so worried about having a built in driving light or indicator if space is too tight.
Moorron
posted on 11/5/15 at 12:20 PM Reply With Quote
After using my car at night for the first time in 7 years I think I can say I want some to replace my Dominators too.
5 3/4 please with housings or suggestions where to get some. But I do like the spider eye 7" versions too (can you get these in the 5 3/4?)
Give us an update when you get back.
Sorry about my spelling, im an engineer and only work in numbers.
karlak
posted on 11/5/15 at 05:59 PM Reply With Quote
Any suggestion where to get 5 3/4 bowls ?
russbost
posted on 14/5/15 at 10:50 AM Reply With Quote
Unfortunately not at present, given the popularity of the Dominator headlight, particularly on bikes, I guess it's possible they may become available, obviously if they do we would almost certainly stock them.
We can get a 90mm unit, but only as separate dip & separate main beam units, not combined
Link
they wouldn't fit the Dominator bowl with massive modification & were horrendously expensive, hence we no longer stock them, tho' we can still get them to order
russbost
posted on 14/5/15 at 10:53 AM Reply With Quote
No particular advice re housings, not something we do at present, I guess the usual suspects like rally design, svc, cbs or ebay.
The "spider eye" style is only available in the 7", everything we can currently get I have pictured
Full update to follow shortly!
russbost
posted on 14/5/15 at 11:12 AM Reply With Quote
Hi All
Sorry it's taken a while for me to get back to you all on this, internet was virtually non-existent in Cuba & very slow & expensive when it did work, hence I haven't made any updates till I got back & first couple of days was busy getting everything back straight - you know what it's like coming back from hols, almost wish you'd never been!
Right, unless lots of you drop out when we need deposit which is now very shortly then the group buy will definitely go ahead, I am contacting my supplier today & would expect an answer by tomo/over the w/e to confirm pricing & availability which I'm not expecting to have changed from my initial post, but it's always best to check these things first.
I will compile a list & will send u2u to each of you to confirm your requirements - if you want lights & haven't got a u2u by the end of today then either u2u me or drop me an email at russbost@googlemail.com
Cheers Russ
russbost
posted on 14/5/15 at 11:22 AM Reply With Quote
Sorry, missed this fist time round! The 7" are 95mm deep, the 5 & 3/4 are 86mm deep, apologies for mixed metric/imperial units!
russbost
posted on 18/5/15 at 11:05 AM Reply With Quote
Have had response from my supplier pricing is as already agreed & delivery should be rather quicker than I had originally suggested, if I get the order in later this week then lights should be delivered to me early in June which is a bit of a bonus.
I will be responding to all u2u's later today with regard to collecting deposits etc. so if you haven't heard from me by end of today please give me a chase up
Cheers Russ
adithorp
posted on 18/5/15 at 11:24 AM Reply With Quote
That'd be great as I might be able to get them fitted before I go away at the end of June.
<<  1    2    3    4  >>
