Author: Subject: Bike Carb Rolling Road - Essex Area??
brown_d9
posted on 27/4/15 at 02:49 PM Reply With Quote
Hi there,
Our Locost is finally completed and ready for a good setup on a rolling road.
Can anyone suggest anywhere that can set up a Zetec / ZX9 Carb / Megajolt setup in the Essex area and what sort of money we should expect to pay.
I have contacted one company who seemed very rude and wanted to charge approx. £450 to set up the carbs and ignition which seemed like a lot to me, but having never done this before I don't really know whats cheap and whats expensive.
I would definetly rather pay a slight premium for a good job though!
Thanks so much in advance.
Dan
snapper
posted on 27/4/15 at 03:44 PM Reply With Quote
I believe ATspeed do bike carbs
I intend to go there when the 2.1 is installed
I eat to survive
I drink to forget
brown_d9
posted on 27/4/15 at 03:57 PM Reply With Quote
Thanks, that's where I have got the above quote for... seems like a lot of money, and the person I have had e-mail contact with dosnt make give me a warm feeling... seems a bit grumpy!
alex1991
posted on 27/4/15 at 04:10 PM Reply With Quote
Seems a little expensive.
I would expect around £250 to £300 but that's going on past experience with injected engines. Not sure how much more (if any) time carbs add.
CosKev3
posted on 27/4/15 at 04:27 PM Reply With Quote
Carbs will add time for sure, as you need to open them up to swap jets/air correctors etc to get it right.
whitestu
posted on 27/4/15 at 04:59 PM Reply With Quote
You could do it yourself.
With a AFR meter and a bit of time the carbs aren't difficult. As for the map I'm using someone else's base map that I tweaked and it works great.
£450 does seem a lot.
Stu
[Edited on 27/4/15 by whitestu]
brown_d9
posted on 27/4/15 at 05:41 PM Reply With Quote
Stu
I think I might well try that, can you suggest a good AFR meter?
Dan
whitestu
posted on 27/4/15 at 05:42 PM Reply With Quote
I made one of the JAW kits which was OK, but I think the innovate ones are better.
Link
Stu
alex1991
posted on 27/4/15 at 06:11 PM Reply With Quote
I've got an innovate lc2. Really good bit of kit.
Connects to a laptop and is easy to record your afr.
brown_d9
posted on 27/4/15 at 06:15 PM Reply With Quote
Thanks guys
Does it screw into a standard lambda sensor socket, or does it need connecting to each individual exhaust pipe?
Dan
whitestu
posted on 27/4/15 at 06:19 PM Reply With Quote
Yes, it goes in a normal lambda socket.
alex1991
posted on 27/4/15 at 06:25 PM Reply With Quote
You want to put the wideband sensor in the collector where it receives exhaust gas from all cylinders (otherwise you will only know the AFR of those select cylinders and some engines (Honda B series cylinder 3 for example) can have a cylinder that runs a bit leaner).
brown_d9
posted on 27/4/15 at 06:27 PM Reply With Quote
Our lambda socket is in the manifold collector so it should work just fine.
Does it come with comprehensive instructions as to what readings we should be aiming for?
Dan
atspeed racing
posted on 29/4/15 at 07:21 AM Reply With Quote
With maybe 50..100 emails a day our replies have to be simple and short.
Bike carbs are time consuming to calibrate correctly, thats the idle, cruise and full throttle not just drilling out the main jet and saying its done.
A wise man once said that the quality of the work will be remembered long after the cost has been forgotten..
jeffw
posted on 29/4/15 at 09:22 AM Reply With Quote
And where else do you see pre-war GP cars and CanAm McLaren's waiting to be tuned while you are there? I highly recommend Atspeed....just remember to give as good as you get as far as verbal banter is concerned
