Author: Subject: MX-5 Throttle Bodies - Lowest cost options?
MilesBuilder
posted on 2/6/15 at 10:04 PM Reply With Quote
Hi, I have a general question about throttle bodies...
I'm getting back into my GBS Zero GT build. It has a Mazda 1.8 MK2 donor, and as the stock air plenum does not fit in the GBS frame, i think I need throttle bodies.
I received a quote from Jenvey, nice kit, but was a lot more than I paid for the whole donor car, at around £1400. GBS offer an ATR DCOE 45mm diameter throttle body kit for similar money I think but difficult to see what is required along with the basic kit.
What have others done for a mazda engine for throttle bodies? Maybe bike engine 45mm diameter ITB?
I have assembled a mega squirt ECU.
I will have a look in MX5nuts website now to see there for any suggestions.
any help welcome,
Thanks,
Miles.
PorkChop
posted on 2/6/15 at 10:39 PM Reply With Quote
You won't find many TB builds on Nutz; they're generally accepted as one of the final tuning steps as the OEM inlet isn't too bad at all, plus they lend themselves more to FI.
Blink Motorsport will supply a TB kit, but they usually follow the above, but they might be able to put something together for you. They're Jenveys IIRC. Skuzzle Motorsport also put together a high power 1600 with bike TBs but there was a lot of other stuff in that engine too.
SJ
posted on 3/6/15 at 07:08 AM Reply With Quote
A fabricated manifold and bike TBs will be your cheapest option.
Slimy38
posted on 3/6/15 at 07:27 AM Reply With Quote
Pretty much what I was going to say, following a similar process to the various Zetec/Duratec TB builds. So 600cc TB's, custom manifold and MS (which you already have)?
I think it's a sensible route if you're considering a lack of space, and I have to admit I love the noise (I would be tempted just on that basis!). But it's not going to give too much of a boost, hence it not being an overly popular solution.
Here's a typical nutz thread;
http://www.mx5nutz.com/forum/index.php?showtopic=99345
big-vee-twin
posted on 3/6/15 at 07:48 AM Reply With Quote
GSXR 750 throttle bodies from a 2001 Suzuki have the same internal dim as Jenveys.
They easily split into individual TB's so ideal for respacing.
Mine are installed into a manifold custom made by Fastdan of this forum.
You will see some pics of my Duratec set up in my archive.
http://www.triangleltd.com
FASTdan
posted on 3/6/15 at 07:53 AM Reply With Quote
We can do you the same kit as below, but to suit your engine for the same price:
Ford Duratec 1.8/2.0/2.3 Bike Throttle Bodies Kit GSXR1000 42mm *STARTER PACK* 2
Or, if you would prefer to do it in kit form we can supply any of the components individually. Drop me an email dan@danstengineering.co.uk.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
SPYDER
posted on 3/6/15 at 08:05 PM Reply With Quote
This is what I did. I respaced them to suit the 3SGE Toyota engine. This also allowed me to re-use my DCOE type K&Ns.
I cut the flange from a standard manifold and made the rest myself. I knocked up a sort of jig to hold the lot in position for welding.
The bodies cost £100. The silicon hose and jubilees £30. The rest cost buttons.
OP...These bodies may be oversized for your 1.8 engine. As already stated, 600cc type might be better suited. I would try to get re-spaceable ones. A perfectly straight inlet has to be better than a kinked one.
MilesBuilder
posted on 4/6/15 at 12:07 AM Reply With Quote
Many thanks to all for replies. Superb feedback.
The bike TB seems the lower cost way to go.
I would have to pull too many favours in our tool room for some self designed turned and welded ally work, and I'd be worried I would not know how to modify linkages and fuel delivery pipes; but looks the best low cost solution by far.
I will email FastDan soon, and go from there.
I can see this is going to be the complex part of this build, my deviation away from stock MX-5 air plenum and stock ecu, and going to throttle bodies and a megaSquirt (V2 I think) self soldered ecu (assembled not tested yet). I need a college course just to get all the variables in the mapping tune understood. It will be crying out for a DOE design of experiments to optimize it I think. but starting with a suggested map from a forum.
I knew I should have gone with GBS' suggestion of a 1.6 donor (where plenums fits), not the 1.8.
Many thanks,
Miles.
