Author: Subject: Duratec inlet side alternator mounting pictures
ceebmoj
posted on 8/6/15 at 11:59 PM Reply With Quote
hi guys please can see some pictures and details of your Duratec inlet side alternator mounting?
[Edited on 8/6/15 by ceebmoj]
Kdempsie
posted on 9/6/15 at 09:41 AM Reply With Quote
Hi, mine is shown here https://jpsc.org.uk/forum/viewtopic.php?t=1209&start=30
It might not be very clear from those pictures though. I didn't do anything clever, just bought the kit from Raceline.
Keith.
mackei23b
posted on 9/6/15 at 12:09 PM Reply With Quote
Not mounted, but here are my home made brackets...
Ian
ceebmoj
posted on 9/6/15 at 06:55 PM Reply With Quote
Which alternator is that and do you need to swap the puly?
big-vee-twin
posted on 9/6/15 at 07:28 PM Reply With Quote
Nippon Denso Alt found on Daihatsu Charade among others pulley from Burton Power.
New Alts can be had from Brise if you have deep pockets.
http://www.triangleltd.com
mackei23b
posted on 10/6/15 at 09:52 AM Reply With Quote
Burton Power for my pulley as well.
Ian
ceebmoj
posted on 12/6/15 at 12:09 AM Reply With Quote
Last question I think. What belt size have you used and what is its origin?
peter030371
posted on 12/6/15 at 07:20 AM Reply With Quote
I have yet to measure up what size belt I need but this site is book marked for the day I do Not used them yet but they seem to have a decent range http://www.camskill.co.uk/m28b0s0p0/Cambelts_Auxilliary_B elts_Drive_Belts_and_Fan_Belts
mackei23b
posted on 15/6/15 at 08:36 AM Reply With Quote
Hi There
A 6PK belt is what is required, any good motor factor will be able to order one in. I use a local motor factor and picked up a belt the same afternoon.
Depending on the bracket used there will be some variation in length. I used some tape and measured the length round the pulleys, if you are plus/minus 15mm the tensioner will still be able to cope with this from its midpoint.
Ian
