James
posted on 18/6/15 at 07:57 PM |
O/T: LED ceiling lights for bathroom
Greetings,
Complete bathroom renovation in progress.
We'd like to fit LED ceiling light units in there.
Any advice/recommendations?
Amongst other things I'm not sure whether to go GU10 fitting or fixed types which as far as I can tell last longer but you bin the whole unit
when it fails.
The Halers are 3x the prices of LEDLite... are they worth it?
Any other viable options?
Thanks!
James
- Muhammad Ali
McLannahan
posted on 18/6/15 at 08:19 PM |
I have GU10 LED down lighters with standard replaceable bulbs and they've been fine. I bought my bulbs from eBay nothing too fancy but not the
cheap ones. Have tried a few of the really cheap bulbs (I even bought some from Poundland) but the warm white has generally been too blue and
they've failed within a few months. Bought a set of four from EBay for about £12 and they're a good colour and have lasted really well.
The two over the bath area have an additional lens to help with moisture the other two are just the standard lights with no lens at all.
SteveWalker
posted on 18/6/15 at 08:23 PM |
I've got 240V GU10s in the second toilet and 12V MR16s in the bathroom, plus more GU10s in the kitchen. I'd personally go for replaceable
lamps, but I've never tried the fixed ones - what are the chances of still being able to buy a matching one if one of the set fail in a few
years?
The kitchen ones are poor, but they are early ones and a bit too dim. The others are good and bright and reliable so far.
12V MR16s can be used with a SELV PSU and can therefore go directly over a bath or in a shower enclosure with no cover (we have one in the centre of
an extractor fan intake), but there is one gotcha with the MR16s - with seven of them, I had the choice of one 12V PSU per pair or triplet or one
larger one for the lot. I went for the latter and despite the total load of the seven leds being in the specified load range, the whole lot flashed on
and off about once a second. I'd heard of the problem and putting one halogen in with six leds works perfectly. Alternatively an old fashioned
transformer PSU would have worked instead of the cheap, but efficient, switched-mode ones that are almost universal now.
[Edited on 18/6/15 by SteveWalker]
posted on 18/6/15 at 08:24 PM |
Read up on bathroom zones before selecting your lights. They might need to be waterproof.
cliftyhanger
posted on 18/6/15 at 08:27 PM |
I have just used bathroom (waterproof) downlighters with replaceable bulbs. After trying a few chep bulbs (smd GU10's) I eventually bought a job
lot of 24 philips ones (actually a bargain at £75) which is enough to do our kitchen and bathrooms. They seem to be just better quality, and so far no
failures.
The downlighters are about £8 a piece......fire rated too (a wise choice for a small amount extra)
daniel mason
posted on 18/6/15 at 08:35 PM |
James. Haler h2 pro without doubt. Fully guaranteed for 7 yeas I think. Very nice,bright,and low wattage. Dimable too.
I can supply you them if you want and will get massive discount from my wholesaler!
daniel mason
posted on 18/6/15 at 08:38 PM |
Also never put an exposed lamp above a shower cubicle.even if 12v !
The heat generated along with the water is not a good mix
SteveWalker
posted on 18/6/15 at 09:45 PM |
Many of the 12V shower lights are designed this way. The led lamps don't get anywhere near as hot as halogens on the front.
daniel mason
posted on 18/6/15 at 09:49 PM |
No,I was referring to a standard mr16 lamp.they get very hot!
We fit a lot of the haler h2 pro and they are very good
stevebubs
posted on 18/6/15 at 11:33 PM |
Useful...
http://www.universal-lighting.co.uk/buying-guides/bathroom-light-zones
Phil.J
posted on 19/6/15 at 07:20 AM |
Just a note, when I fitted LED lights in our bathroom the transistor radio I listen to when in the shower would no longer work, yhe signal is drowned
out with noise.
James
posted on 19/6/15 at 08:48 PM |
Thanks for all the responses folks!
- Muhammad Ali
lsdweb
posted on 23/6/15 at 04:16 PM |
Zones aside, have a look at Screwfix for GU10 LED replacement lamps. They have special offers on regularly for the multipacks and come with a three
year guarantee. We have three properties with a lot of GU10s (2 flats, each with over 20 downlights) and I've replaced them all with the
Screwfix (Electrafix for me) lamps without problems.
Regards
Wyn
Screwfix LAP LEDS
