sdh2903
| posted on 23/6/15 at 07:08 PM |
Mx5 mk1 rear hub wanted
As above need a rear hub for a mk1 mx5 please as it sustained damage during separation from driveshaft!!
Only need the hub but would take an upright if you can't be arsed removing the hub.
steve
clairetoo
| posted on 23/6/15 at 07:59 PM |
I've got one here with a dead bearing and a rusted-in lower bolt.........any use ?
Postage might kill it , but its free.............
Its cuz I is blond , innit
Claire xx
Will weld for food......
sdh2903
| posted on 23/6/15 at 08:19 PM |
Hi Claire. As long as the hub itself is ok that would be spot on. I've got a full new set of bearings ready to fit anyway.
If you let me know how much to post would paypal be ok?
clairetoo
| posted on 23/6/15 at 09:43 PM |
Just back in from the shed.........
I'll check tomorrow , and let you know
Claire xx
sdh2903
| posted on 23/6/15 at 09:47 PM |
Ta very much!
| posted on 24/6/15 at 11:56 AM |
What happened to the hub during removing the shaft?
Just asking as I am struggling to get the shaft out of mine!
sdh2903
| posted on 24/6/15 at 01:06 PM |
I happened to it!! Lost my rag trying to get the shaft out and took a chunk of it off.
I eventually got the shaft out after 3 days soaking in penetrating oil. Then in my 12 ton press at max pressure then a smack on the hub and it finally
popped out.
| posted on 24/6/15 at 02:18 PM |
Ok, mine been in the vice for about 5 weeks soaking in penetrating oil!!!
sdh2903
| posted on 24/6/15 at 02:30 PM |
You've obviously got way more patience than me
sdh2903
| posted on 29/6/15 at 06:03 PM |
Any joy Claire?
