Author: Subject: It's not rocket science
ken555
posted on 23/7/15 at 09:09 PM Reply With Quote
Nasa documents for electrical connection etc. Always worth a read. Page 80 is great for joining cables.
http://www.hq.nasa.gov/office/codeq/doctree/87394.pdf
bi22le
posted on 23/7/15 at 09:38 PM Reply With Quote
Page 46 mentions cable ties and spiral wrap.
Please read my ring story:
coyoteboy
posted on 23/7/15 at 10:03 PM Reply With Quote
It's a part of my day job. ESA have similar docs. I keep copies of both on my desk for reference!
posted on 23/7/15 at 10:06 PM Reply With Quote
I guess these standards explain why NASA can land craft on comets gazillions of miles away, yet I can barely make an lighting connection last a winter!
It's Evolution Baby!
ste
posted on 23/7/15 at 10:26 PM Reply With Quote
Very outdated stuff on there. I work on Eurofighters and most joints are crimped as they are more reliable.
coyoteboy
posted on 24/7/15 at 01:08 AM Reply With Quote
Not out of date, you may just have missed the fact that crimps are used but that there are significantly more constraining design drivers in space hardware. There is a general reluctance to use new kit if old kit/methods are proven to work flawlessly though I give you that. But that's generally because space builds are one-off, mentally high value and there's no one rushing you to find a faster, cheaper way of producing something that has to work flawlessly in the vacuum of space, swinging between -200 and +200 many times a day and can never be inspected, replaced, bypassed etc. NASA/ESA test things like this as they come available in projects and update as soon as a better solution or method is available and qualified.
The vibration requirements for MIL/plane hardware is pretty harsh, duration-wise, our vibration is limited to a few minutes, after that loadings are largely thermal induced or self generated.
What crimps are used on the Eurofighter and in what sort of locations?
Check out the ESA crimping standards for more fun reading.
[Edited on 24/7/15 by coyoteboy]
lsdweb
posted on 24/7/15 at 07:18 AM Reply With Quote
Very interesting - thanks for posting the link!
I wouldn't get past page 25 unfortunately (colour vision test!)
Wyn
Irony
posted on 24/7/15 at 07:48 AM Reply With Quote
This is a great thread. It should be stickied at the top of the electrical section. It is great to have some sort of a official document regarding this much argued over topic. Thanks guys.
P.S I'm a crimper by the way.
ste
posted on 27/7/15 at 12:00 AM Reply With Quote
Technical drawings I can't post as they are covered under the official secrets act.
Some off the internet here
http://www.peigenesis.com/en/amphenol-connectors/amphenol-sjt-series-mil-dtl-38999-type-1-5.html#contact-crimping
I fully understand why the methods are used for space, it takes a lot to qualify parts and techniques for aerospace
coyoteboy
posted on 29/7/15 at 08:00 PM Reply With Quote
Yep, good old amphenols - fairly commonly used but massively over-sized for the bulk of our work! (we do mainly subsystems, not harnessing) Customers generally specify D-sub connectors, often Positronic, but usually crimp terms - we just provide the black boxes and/or harnesses to suit. I'd still say 50% of the larger connectors we use are solder-bucket types, and wicking is controlled, plus additional strain relief in the form of heat shrink or separate support struts used. Plus it's normal for us to tie down at ~50mm intervals on large harnesses.
coyoteboy
[Edited on 29/7/15 by coyoteboy]
DaveFJ
posted on 31/7/15 at 11:57 AM Reply With Quote
Interesting that they specify that ty-wraps should always have the 'ribbed' side touching the wires.
When I was working on military helicopters we had to use 'special' ty-wraps with an external ratchet so that the ribs did not fret the wires......
Dave
