waggy
| posted on 2/9/15 at 11:54 AM |
Clearout lots of parts locost and westfield.
This is a pretty long list, I will mark off each part as sold or provisionally sold as required, selling as I have no garage at my new house yet and I
don't want the parts in my spare room any longer..... Well when I say "I don't "I actually mean the missus doesn't.
I'm open to offers on items and not sure what to ask for most things.
Alloy fuel tank has been powder coated black on outside this is a beautiful piece of kit. Aprox 800mmlength x200mm height and is wedge shaped to suit
Westfield or locost. NEW
Engine cradle for fireblade engine from megablade, ideal for conversion or to leave race spare ready to drop in or suitable for locost
English 3.54 Diff in perfect condition no pitting at all on gears.
English axle case all brackets removed ready for brackets to be welded on.
Rs2000 English half shafts, pair.
Rs2000 English half shafts , pair, turned down 4mm to accept disc conversion.
Sierra handbrake handle complete with switch and the dangly bit. Sorry for the poor terminology.
Cortina ball joints NEW
Full set of front wishbones, locost complete with bushes and ball joints.
Westfield astrali steering wheel hub kit westfield to 6 bolt wheel. NEW but quite old.
Full set of locost poly bushes with inserts and crush tubes. NEW
Vx220 ball joints x 4 NEW
Sierra steering column updated bush for where it passes chassis at pedal box, not sure if this is the right description! NEW
Steering rack mounting plate, laser cut, for locost or Haynes roadster NEW
Alloy hubs for cortina/ Westfield NEW
Cortina front wheel bearings NEW
Cortina front bearing castle nut cover things, one NEW one used.
Westfield front wishbones, full set, with ball joints and bushes in very good condition.
Mk2 escort steering rack clamps in good condition with bushes.
Locost full set of wishbone and front suspension brackets laser cut. NEW
Locost rear axle brackets Panhard rod brackets and trailing arm brackets laser cut NEW
Westfield coilovers full set in VGood condition.
QH maxi ball joints x2 NEW
Cortina/Westfield new front discs ferodo solid discs. NEW
Type 16 calipers stripped down for rebuild or could be used for exchange.
Type 16 Caliper pins NEW
Type 16 caliper seal kit NEW
Locost Panhard rod and trailing arms with bushes have been fitted never used on road.
Rear discs to suit english axle. NEW
English axle caliper brackets weld on NEW
English axle caliper brackets bolt on NEW
English axle new bearings
English axle new half shaft bolts
English axle new diff seal
English axle new pinion seal
Mk 2 escort steering racks x3 all in good condition, one has been reconditioned and not used since.
Sierra steering column with ignition barel and key, non adjustable one.
Sierra steering column extension.
Sierra rear calipers and carriers pair ready to go. Solid disc pair
Sierra rear calipers no carriers for refurb or exchange. Solid disc pair
Sierra caliper carriers x3
Sierra caliper and carrier vented RHS NEW
Sierra pedal box
Allegro/Westfield steering column, still needs to be stripped down, column is complete with cage stalks ignition barrel and key also have fuel cap.
Do the right thing, right, first time!
If only it was that simple!
smac
| posted on 2/9/15 at 12:23 PM |
Hi
Interested in the wishbones. Do you have sizes and photos & an idea of what you'd like for them?
Simon
kingster996
| posted on 2/9/15 at 12:30 PM |
PM sent
I used to be indecisive, but now I'm not so sure
waggy
| posted on 2/9/15 at 01:41 PM |
Simon,
Which wishbones is it you'd like to know about?
The locost or the westfield?
I'm really struggling with the prices to ask for things, especially the new stuff!!
I know what I paid for the most part, but I don't know what to ask for things. Make me an offer I'll likely say yes if it's anything
reasonable.
smac
| posted on 2/9/15 at 04:02 PM |
The Locost ones please
slingshot2000
| posted on 2/9/15 at 04:25 PM |
I would be interested in the engine cradle if you could let me have an idea of the price.
Jon
19sac65
| posted on 2/9/15 at 05:29 PM |
Pm sent re diff
Lander
| posted on 2/9/15 at 07:20 PM |
How much for the handbrake?
Ian
waggy
| posted on 2/9/15 at 08:01 PM |
Make me an offer on it.
Barkalarr
| posted on 2/9/15 at 11:18 PM |
Interested in the Sierra Rear Calipers - can you shoot me a picture please.
locost7-online.com
| posted on 4/9/15 at 07:04 PM |
Hi I'm interested in a mk 2 escort steering rack, what ratios are they?. And clamps too
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
waggy
| posted on 4/9/15 at 07:22 PM |
I'm just about to update the thread but the reconditioned rack and clamps are sold. I have two others that are for sale both work fine one needs
a bit of a tidy up and gaiters. You could have them cheap if you pm me.
Thanks.
waggy
| posted on 4/9/15 at 07:33 PM |
UPDATED, only sold items removed.
Westfield front wishbones, full set, with bushes in very good condition.
Mk 2 escort steering racks x2.
Sierra pedal box
donn006
| posted on 4/9/15 at 09:12 PM |
Hi mate I'm interested in the bolt on calliper brackets
waggy
| posted on 13/9/15 at 08:14 PM |
UPDATED, plus new items added
Cortina stub axles
Cortina steel hubs
Top balljoints for front wishbones NEW
Westfield bottom ball joints for front wishbones NEW
Sierra pedal box
ollymonkeynuts
| posted on 31/10/15 at 10:15 PM |
wishbones
Hello, Im interested in your....
Do you still have them and what would you be thinking for them please?
Many thanks, Olly
matty h
| posted on 1/11/15 at 05:34 PM |
Could be intrested in tank and/or westfield coilovers.
PM sent.
Matty
NWBhaslett
| posted on 12/8/16 at 10:39 AM |
Would be interested in few bits if you have them:
- Top balljoints for front wishbones NEW
- Westfield bottom ball joints for front wishbones NEW
Wouldn't happen to have any Westfield Front Wisbhone Brackets?
Where in Northern Ireland are you?
Brent
Mark100
| posted on 13/8/16 at 10:17 AM |
sierra calipers ready to go picks and details please
